This is soo easy to fix...
Do an AFM bypass then get your PFC tuned to suit.
You will get double the range out of your AFM for free exept for the cost of a quick retune.
Basicly get a Y connector like you said but just dont have an AFM on one of them... so only 50% of air or so is messured and dyno will fix up the timing and Air Fuel mixtures to handle it.
I had recently borrowed my mates power fc kit.. for an rb25..
Power FC and a few other bits and pieces including a very large AFM.
I beleive it was off a subaru of some description..
The only difference was the wires.. so after measuring the wires around, I found that I had to change signal and common wires around... worked a charm, but was only running stock boost, and was tuned for 550cc injectors.. so naturally my car was slower than with the stock afm..
I'd say try and find a larger afm with 3 wires.. Its not that difficult to change the wires around, and you should be able to get higher values.. so therefore the result that you want.
Or otherwise change the thermistor inside your Z32 AFM to a different temerature co-efficient.. that might also get you higher vlaues with more boost pressure.. But yeah might have trouble with the amount of air you are able to pass through the Z32 area..
just my 20cents worth ;)
what if you had a twin setup? i am very interested as i have bought a working rb25dett setup, but have an rb25 power fc. i also have an safc so was going to use that, but this looks much better?
if i use a dead afm on one turbos intake, and a "live" one on the other, than they should have the same inlet restriction right... i need guidance for the cheapest/easiest way out lol.
turbos are from r33 gtr
  • 3 months later...
I'm still doing a bit of research on this area because I DO want to go for a dual afm setup if only because nobody else has done it yet :)
Anybody know where I can buy a prefabricated Y-pipe like this one on the picture? it's from a singelturbo rb26dett conversion:
Makes sense to use a dummy afm as long as you have the same pod and pipe dimentions, and the filters in a spot where they can suck the exact same amount of air...
I'm still doing a bit of research on this area because I DO want to go for a dual afm setup if only because nobody else has done it yet :devil:
http://www.nengun.com/trust-greddy/suction-pipe
Was thinking of another application as well, since one of the problems with airbox's is how restrictive they are once you start getting high up in the horsepower range, could you possibly run another pipe underneath the intake (assuming its a low mount and the pipe would be heading towards the ground) pipe, this would give extra flow and be hidden from unwanted eyes.
Also if this is done on the first batch of upgrades of turbo and injectors would it allow you to keep the factory afm or would you still need to use a z32?
If the bypass pipe was an appropriate diameter, there is no reason you couldnt use the standard AFM. One thing to bear in mind, is that you would want the bypass to flow roughly the same amount of air as the AFM, and make sure you clean the airfilters at the same time, as any differential from when the car is tuned could cause a drastic change in the A/F ratio
just an update.. on my twins i have them both being fed through a single afm. this was the only way we could accurately meter the air going in, and you have to know how much is in each turbo.
so im running a big afm and rb25 power fc
  • 6 years later...
Ive been researching this topic in regards to my afm "hitting the ceiling" so to speak, if 2 afm's wired in parallel gave the same/equal voltage output but at half the value of the single afm, could i just double the percentage the power fc see's? Or tune to suit?
I believe this would be a more accurate way to measure load as aposed to the bypass inlet idea?
Ideas?
I was running a z32, but was having issues with it, it was giving and/or the power fc was reading it as a noisy signal, like it was ever so slightly out of tune?
Hard to explain, it was always 1 cell off where it should be, or the load ramp table needed modifying. I put the stock afm back in and went back to the power intake setting and was sweet. But it hits 5v at 3/4 power.
Rather than run 2, here's another budget idea. Chop up a stock afm and put it into a larger pipe, maybe 3.5 or 4 inch.
I saw a pic of a z32 cut up and put into a pipe, will try to find it again.
  • Like 1
Sweet idea, might give that ago.
Ive seen the r35 afm design, i thought about that too but I'd need the load ramp table to start off with.
Also, Can the standard table be stretched out with datalogit?
To cover a broader airflow.
Sounds good in theory, but how well will it handle 20+ psi of boost?
And how well can it correctly read air temp?
Seeing it will either be mounted on the hot side of the charge or the cold side of the charge?
Im not entirely convinced it would work 100% correct all the time?
    • Uncle Duncan Yeap, FI Interchiller  Works well, normal IAT's cruising with the WTA only went from 50°c+ to 25-30°c with the interchiller  Before, when on it hard, the IAT would see 80-90°c, now, the highest has been was around 38°c IIRC I recommend it for the street or strip where your only on it hard for 10 or so seconds, but it wouldn't be efficient for sustained track use as it would heat soak from the AC turning off or whatever it does during WOT to protect the compressor It really needs the AC running for it to not heat soak and keep the WTA coolant chilled My WTA coolant temps when just cruising is around 2°c
    • Hey Mark...sorry to interrupt your career change to hair dressing... but...did you ever fit the interchiller to the commodore, and if so how was it? And, who made it?
    • I've been pondering this, I really enjoy the convertible thing, for me, it's like riding a motorbike, without all the issue of riding a motorbike, mainly, my old sore arthritic joints getting beaten up, and, being able to do it in shorts and a T-shirt and not needing a helmet and all the other gear required, especially like wearing jackets and pants in the summer, or needing 6 layers of cloths in the winter, or not having wet weather gear handy when your 100km away from home on the bike when it decides to start raining As for the hard top and its Coupe look, whilst I do lose all that open top feeling that I really enjoy, from my experience with the NB with a detachable hard top, the cabin is a much nicer place to be, the difference in noise for one, a hard top quietens down the interior, alot, with the soft top up or down it's pretty noisy, which, after 5 or so hours, can get tiring But, as you stated, the detachable hard top totally changes the look of the car, in a really good way, and for me, the look of a detachable hard top is so much better than the PRHT which looks more like a after thought with its weird bulbous rear roof line For me, the minimal effort of putting in on, or storing it after removing it, is well worth the time and effort for the look alone And yes, I'm sure the next owner will be grateful for it as well.......
    • I get into huffs with people when I suggest the MX5 looks so much better as a coupe than it does as convertible. Pretty sure I don't prefer the convertible version of anything. Good job on the hardtop! The next buyer will appreciate.
    • IMO wrap does have its uses, but like you said, quality wrap, and professional installation, would probably cost want a quality paint job does, but, the paint, if maintained, is basically for life, and much easier to touch up if required  In other news: it's pissing down here, with thunder, lightning and only some small hail "at this stage", luckily all "my" cars are undercover  I've also been contacted by a guy in Newcastle about the SS, he said he will come down next weekend for a look, we'll see how that transpires I guess 🫰
