wow! all the peices looks really good, i was going to get into over the uni holidayz and i think i just might looks like alot of effort but well worth the finished product (i hope) i going to buy a small bench ginder tomorrow (it is 125mm, 150watt, is this too small)??
yep. i did my plenum all by hand sanding it. man, u will know when to start buffing man, will be soooo smooth. it is totally worth it, just take your time, and dont rush
  • Replies 49
Posted Images
  • 5 months later...
Post #17 I said...
"I’m never polishing anything again, at least nothing as complicated as an RB26 inlet plenum!"
Well, I must be a sadist, as bored yesterday, I paint stripped, cleaned, file finished and almost finished running a paper wheel over the stock BNR32 IC.
Now 6hours of sanding - yay. Worst part is, im not even into the shiny look. I want it to go natural matt silver.
I blame idle hands & beer + pinch of resentment over US shipping times.
Edited by GeeTR
  • 1 month later...
www.yellowpages.com.au :ermm:
on another note.. i did my silvia's intercooler piping to 1500 or 2000 grit wetndry on the stainless piping.. NEVER again.. turned out great tho but f**k that.. closest ill come to polishing now is hitting welds on ic piping to take the burn mark off with the hard stitched wheel.. other than that i try to buy my piping polished already.. saves me alota work
www.yellowpages.com.au :wacko:
Have you tried Ali-Brite on your welds? i have a bottle just need to try it out. Mate of mine swears by this stuff to clean the oxide off the welds, less work on the polishing wheel
Ali-Brite is basically sulfuric acid and water. i have some of my old learning welds, just need some time to run a test with this stuff.
Other trick with the welds, pre soaped steel wool from coles - works awesome as the marks from that buff out easy too.
Please explain how you polished parts using the yellow pages ?
Do you use the white pages first and then the yellow or is it the other way around ???
hahahaha - im guessing he'll be outsourcing polishing from now on
i have been meaning to buy some more pickling paste :wacko:
and yes.. i absolutely hate polishing if i can i get it done elsewhere
    • Hey, like MBS206 mentioned; I dropped off my short block and rotating assembly Monday. With a quick verification, he believes he can clear it up with just a hone and new rings but he will confirm once the rotating assembly is out. If I were you, I would either go stroker or just replace the block if it does need to be bored over to next size. Block is cheaper then forged pistons.
    • live in the UK, and London has introduced a Low Emission Zone (LEZ) that requires individuals to pay £13 if their car doesn’t meet the required emissions standards.   The standard specifies that NOx emissions must be less than 0.08 g/km (i.e., the vehicle must meet Euro 4 standards or better, which generally results in NOx levels of around 0.08 grams per kilometer).   I reached out to Nissan UK, and they advised me to contact Nissan Japan directly. Does anyone have contact details for Nissan Japan or any certifications of conformity that show the emission details or NOx levels for the RB25DET engine?   Any guidance would be greatly appreciated.
    • these guys recommended to me and supplied custom 4 inch mufflers, couldn't be happier. They will spec a muffler to your preferred level of sound and know RB's well.  https://spmufflers.com.au/
    • Yeah this used to happen to me every year and a quick call would at least raise the agreed value back up / reduce the premium, but usually both.    That said for the first time on the renewal this year our agreed values went up or stayed the same over the fleet and the premium came down so that was a nice surprise.
    • I don't even go that hard core. I just say "how do you expect me to stay, when you increase my premium, and reduce the value of the car?"   Then play a game of shut the f**k up. Most of the time it's a computer that did the adjustment, and the people will happily change it around for you.
