get a new O2 sensor, might help efficiency, same goes with new fuel filter, fresh oil etc (ie service)
Id be looking at a Nismo fuel pressure regulator, SAFC2, Bosch 040 fuel pump (direct battery feed) along with the tune :D but depends on what your goal is.
Goal is definitely via the budget at the moment! Sounds like a good service and tune for now then.What cost am i looking at for o2 sensor?
Is it worth the $$ considering the only 'mod' i have is a Trust Airinx GT panel filter? I was hoping a tune might/will increase fuel efficiency. Thoughts?
Very little you can do without some kind of "tunable" ecu (piggyback or complete replacement, a topic which has been covered many times on this forum).
I think the only thing a dyno will allow you to do is maybe add some ignition timing safely (which will likely help with fuel economy a little, and give a bit more power/response) and also give you a baseline kw readout as well as show you your Air/Fuel ratio graph.
A piggyback ecu like the SAFC2 (Apexi Super Air Flow Converter) will allow you to tune the Air/Fuel ratios (AFR) and something like the SITC (Super Ignition Timing Converter) will allow you to tune your ignition timing independently. If you have an SAFC but not an SITC, you will notice that tuning the AFR's will also affect your ignition timing as a side-effect. The SITC allows you to adjust ignition timing independently of AFR's, thus giving you more control over the tune.
Rough guess - you'd be looking at about ~120-125awkw at the moment (approx. 140-145rwkw if you use a 2wd dyno). I personally dont think an air filter will show much performance gain. I have an apexi one, but I couldn't honestly say it gives me any more kw than a standard filter. I've also used a K&N filter on a previous turbo car. After AFM problems from it, I replaced it with a cheap bosch one and couldn't tell the difference in performance.
The one modification with the biggest power gain will be an exhaust. That should give you ~20awkw on its own if you get a good free-flowing one (although it will make the car a bit louder - make sure you get 2 mufflers - NOT a resonator - to reduce drone due to the large boot).
After that an SAFC and a bit more boost will happily see you getting over 150-160awkw, but dont go over about 11 psi on the stock turbo if you want it to last. :D
Good luck with it. :D
PS. I'd definitely prefer boostworx to turbotune. Shaun has a lot more experience with tuning nissan imports and many people on this forum trust and recommend him and dont take their cars anywhere else. :D
good post Steve.
thing is, if you are doing an safc, youd be crazy not to add a Z32 afm, a Nismo FPR and a better fuel pump. These 3 items help so much in terms of giving more 'tuneability' to the ecu piggyback.
what is your current fuel economy ?
as standard (pod filter and catback zaust) I had 120awkw with around 460kms to the empty tank, 1st mods (finished zuast, r34 smic, fpr, safc) got to 140awkw with around 450kms to empty tank, then retuned again with sitc, fuel pump, fmic etc got 160awkw at 12psi, then last tune with a highflow turbo I get ~180awkw with around 440kms to empty.
cant complain with that fuel economy, seeing Ive increased power by over 50% (way more in it, final tune coming up soon enough). oil filter relocation kit, new oil and filter, cam gear wheel, and 1.1bar boost. expect 200awkw and roughyl same economy.
good post Steve.
That sounds good too Brenden, but will be too much $$ to do straight away so they will be done over some time I think. Not really wanting to go crazy with the mods as it is after all used by the boss too, quite happy with power at the moment and an increase with an exhaust. Last tank I got 13.3l/100kms with a trip to the Barossa in there. I dumped a bottle of Nulon injector cleaner in that tank which definitely helped, compared to the last tank. Might get some Redline injector cleaner for the next tank and see how that goes. So I'm thinking it's not so bad, and this is before a proper tune too.
standard turbo is unlikely to max out the afm so no need for a Z32.
unlikely to max out the injectors so no need for an FPR.
unlikely to max out fuel pump so no need for bigger fuel pump.
SAFC, a bleed valve are all bang for your buck mods.
incorrect; in the terms that they ALL help aid the tune
I can vouch for that, sure its not all necessary, nothing is, but they ALL aid in helping sort out a real nice tune.
yup
it all comes down to the fact "how far do you want to go"
and when you are doing it "what is the budget"
Nismo fpr $160 delivered Nengun
Bosch 040 $200 delivered
Z32 second hand $150 delivered
safc - search for best price.
I can guarantee when using a SAFC that the FPR helps sort out the tune - youd be foolish to install a safc and not a fpr, and so does Z32 (higher resolution for air intake measuring), fuel pump may or may not be overkill, each to their own tho. Im not going to preach to you what works for me
tangles did it occur to you that using your hi-flow you are:
a. on the limit of resolution of the standard AFM
b. close to maxing your injectors
c. on the limit of your fuel pump
hence all the above items are necessary or close enough in your case.
standard turbo......should not require any of these items.
sorry dude, pls dont try to make me out as a fool - I might come across that way (quite deliberately) now and then and take the piss outa myself, but I learn fast and research thouroughly................
my case example: standard turbo, cat back exhaust, bleed valve. 120awkw, 2yrs ago now.
supplied a safc, and with my readings from this site supplied a nismo fpr due to the fact that the fpr maintains the rail pressure that you are altering when using a safc. but using a fpr (cause you are using a safc) leans the fuel pump a bit, obviously. from that tune (140awkw) the standard afm was looking a bit cockeyed, wasnt working well at all, so it was thoroughly recommened to me at the time by the respected tuner to get a z32 afm for the next tune.
next tune, finished off exhaust with the dump pipe, added fmic, and supplied the larger afm as the z32 provides greater gain and measurement of the air, being used with a safc and fpr it seemed "normal" to do this, considering it was recommened but the engine tuner. also added a sitc and fuel pump. fuel pump was added to make sure I had no issues with fuel, seeing a z32afm/sitc/fpr/safc were being used. why do all this and risk leaning out the fuel pump? that was 160awkw standard turbo.
added the highflow (always had the goal to do this) and at same psi gained ~25awkw outa the box.
so yes in my case it comes down to your overall plans.
as I said before, depends on how far you want to go. depends on budget, but a $150 fpr wont break the bank, nor would same price for z32 afm.
BUT, in summary, I wouldnt add a safc without also adding a fpr. then by adding a fpr you should consider a bigger fuel pump, eventually, each car/engine is different tho, horses for courses. why lean too hard on the stnd pussy 10yr old fuel pump? z32 afm has greater tuneabililty than stnd afm...... my course of action with the 1st/2nd tune showed up the afm, could have been unlucky but again just my particular story.
highflow turbo was the last thing I added, everything else was good and ready for it.
So that should be about what i get then with my 206kW Neo6 engine with just a hi flow panel filter?
Set your expectations at about 110awkw just so you dont get disappointed if its not what you want. Remember that all dyno's will read differently from each other and also possibly different on any given day, as your car will run better some days than others. I had my car dyno'd at 157awkw on a ~35 degree day and I only have the standard S2/R34 SMIC so I'd argue that it would definitely get a better reading on a cold day. I can notice the difference after driving for say 20 minutes, ie. cooling issues. It always feels faster when its cold (ie. engine heated up to efficient running temperature but intercooler and intake temps still cold).
Tangles (and others), thanks for the compliments - I was just putting together most of the things I've picked up from this forum and my own (limited) experience with turbo nissans.
When my car was stock I got 13.5-14L/100km in town and 10.7L/100km on the highway. Now with significantly more power (had an exhaust manifold leak when I bought the car which gave it only 100awkw, compared to ~160awkw now), I'm getting 11.5-12L/100km in town and have seen 9L/100km on the highway (brisbane to goondiwindi, early morning). Thats a huge improvement in fuel economy AND performance which is a very nice achievement in my opinion. Mostly thanks to the exhaust for freeing up the engine and the bigger turbo for keeping it off boost in town. :)
I too have ~160awkw at 12psi, although as my sig states, at the top end of my dyno its actually only running 9psi (boost controller cant keep up) so if it had 12psi all the way through I could pick up maybe an extra 10awkw?
My wishlist for the car is a mile long and realistically none of it will probably happen. I have so many maintenance items now coming up that I need to pay for otherwise I wont be able to afford to even keep the car :) Things like new tires, brakes, possibly radius rod bushes, possibly front shocks and springs, and its due for an engine and transmission service...it all just creeps up on you. Its a lot of money that I would have happily spent on a FMIC and SITC (hello 180+awkw@14psi!!!) but we all know that part of owning a car is keeping up with all the boring stuff like servicing etc. ;)
tangles, i am not trying to make you out as a fool.
i am disagreeing (also based on facts). nothing more nothing less.
sorry dude, yeah I know that..... my bad.
long hard tiring day last friday.
Im still keen tho with the safc + adj.fpr tho, thats all.
    • I know mentally you're set on the ATS clutch but honestly I'm a big fan of the Nismo Super Coppermix Twin. It's much cheaper and in some ways I think it's a better design for a street/circuit car.
    • Just checked in first post and you should be able to bring it home November this year, right? I'm amazed you made it through four years of this. As hard as it feels now the rest will go by in a breeze in hindsight, I'm sure.
    • Realized I haven't been back here in a while. Still here, still alive, still waiting for the car.  I went back again the only time last year from Oct-Nov for R's Meeting and drove it around some more, including a few laps on Fuji Speedway(in the wet, sadly). The car still feels good, but have a couple small things to address. I've been getting more parts but have slowed down still, and most of the bigger purchases are now out of the way. I find myself getting impatient more and more when it comes to getting started on this project; it's quite hard for me not being able to really dive in and start making this car my own because it's halfway across the world. At times it doesn't even really feel like I own one of these. Haven't really been motivated or had the desire to document the last trip on here or social media for, well, reasons... but here's some pics...it's also still alive and well as you can see: I've narrowed down to the last large part purchases(anything over $2k) before the engine build to be: 1) Ohlins Road & Tracks 2) ATS Twin Carbon clutch 3) Endless BBK with some custom options and 4) Kansai Service carbon driveshaft I don't think the budget exists for all of these this year, but I'll try for one or two items I think. Though, every time I look at my spreadsheet I sigh, shake my head, and get depressed just that little bit more.  'til later.
    • It's a stunning location!  I've been to NZ twice but haven't made it to the North Island yet.  Definitely on the cards but the South Island is hard to tear yourself away from too... Looking forward to see what you can wring out of it once you can get it to hold together!  Be awesome to get a low 11 or even sneaking into the high 10's pass out of it.  That's a bloody quick car that most people will never experience in their life.  Enjoy!
    • Nominally yes but I’m not really at that stage yet. Outsourcing to Japan is also a relatively good deal at the moment because their currency has devalued much more against the USD.  You would assume this but a lot has changed from the pandemic. Mechanics are in short supply and demand for fixing old cars has gone up from the cost of new cars. 250-300 USD/hr is not an unusual shop labor rate in California and you’re paying that regardless of whether the guy is competent or not. Coworkers have been quoted 3000 USD for a water pump and thermostat at a dealer on an N54. Oil changes went from ~75 USD to 150 on fairly normal cars like Civics. The cost of the oil and filter hasn’t even kept up with inflation.
