hey, ive just spoken to the guy who built my engine and he tells me that running over 400hp i will need to drill out original head stud hole in block and increase size from standard 10mm to 12mm....i have an ARP 10mm headstud kit already in it but apparently its no better than stock cos the setup isnt a torque to yeild design, what are your views??? i WONT pull it apart and do this as u need to strip engine down to bare block and get holes drilled by vertical mill(from what im told) so i'd rather get a different engine made but was going to order my 35/40, splitfire coils and ebc tomorrow but wont till i know that he's just scaring me............ i got o-ringed block with an o-ring recess in the head and 1.6mm copper gasket and arp headstud kit...please let me know if you've heard the same???
https://www.sau.com.au/forums/topic/177240-do-i-need-head-bolt-upgrade/
indeed.
There are plenty of big power cars getting around with std head bolts, let alone ARP studs. Look at all the SOHC RB30's making spastic power. I think he's getting head gasket issues confused with lifting head issues.
Like Nismoid said - unless he was running super low comp with massive boost previously.
indeed.
ok, thats kinda relieving......the last thing i want is to pop a head gasket again... wat a bastard.. guess i'll just see how it goes, been running for about a 1000k since last gasket was changed so might retention it maybe to be safe..........
when i built my engine i just ordered brand new head studs from nissan (standard ones) and chucked the old ones out. I got 487rwhp. One of the guys in melbourne i talked to when buying some VL turbo go fast bits for my mates car said that anything around 33psi of boost and then you will lift the head on the standard setup.
Standard 25 or 30 head bolts are 11mm. You shouldn't have a problem at that size but I'd check the length of the bolts against each other and replace them if there is more than .5mm or so difference in the underhead length.
33psi ey, interesting... the highest cylinder pressures occur during the combustion stroke which is more related to airflow/power made rather then outright psi.
more power, more bang, higher cylinder pressures. clear cut 33psi sounds like hes experienced it once at that level and believes it applies to all.
    • It's the adhesive holding the ceramic wheel to the shaft the fails on 90% of them.
    • Foreign debris, physical shock, boost leak, could be anything honestly. The danger in taking all the timing out of a tune/hitting the R&R corner is that even if the engine doesn't detonate your turbo is taking a lot of abuse from high EGT. Also, even if nothing goes wrong it is a journal bearing that is spinning at 100k RPM on boost. Eventually it goes through enough cold start/pressure cycles to wear it out.
    • I kinda accidentally saw this, and was interested, but It actually seems to replaces the whole center computer, using the existing screen and buttons. AND it may only be for a G37 and not compatible with a Japanese 370. So its not for me, but someone else may be interested to look into it. Its about $680USD. If I am understanding it right, it basically replaces/installs and android pc that integrates with the existing screen. But I could be wrong. https://gromaudio.com/vline/ The video I first saw was the following, with very little and unclear details.     Even if your not interested in the system, the video on their site was pretty comforting in showing how simple the whole centre comes out
    • hfygrte52 what side you looking for? Do you care what color car it's off? Found a white LH side on here: https://skylinespares.com.au/product/nissan-skyline-r33-coupe-rear-tail-light/   Aussie parts place but will ship to USA. Maybe get it before there's a tarrif on 25yo shit box parts
    • I’m with Shannon’s for all 5 of our cars. Agreed values seem fair, premium price is okay. ($210 ish a month, all comprehensive).  Have claimed once with them for a not at fault claim with another car where my car had no damage. Was one call after the incident and an email after. Deemed not at fault so premium didn’t go up either.    I have called up and spoken with people who are not familiar with certain cars and didn’t agree with me on value or let their personal vehicle preferences effect the call. But called back later and got someone else who was more agreeable.
