I have been posted those wheels for sale while ago, had no lock due to lack of interest buyer came to me, so decided to keep for another month.
This is just a feeler if someone take my offer or close to that, will be sold straight away as I want something different style.
The wheels are Rays 99B, front ET25, rear ET22, perfect fitment for V35 coupe and 350Z. It's been used for about 4.5 months, put lots of care on the wheels. The condition is just like brand new, except one minor scratch on one of the rear wheel.
still have original warranty card for 4 wheels and 4 original Rays box.
The front tyre is Falken 451 245/35, rear is Dunlop SP9000 275/35. Both have 90% tread
paid $4650 for wheels and tyres, looking for $3300
Edited by spikey
https://www.sau.com.au/forums/topic/177258-feeler-rays-99b-19x8519x95/
The one I sent you was taken by phone.
I have a sony T9, still learning how to take picture!!!
get a trippod, set to manual mode, turn off the flash, set a reasonable speed say: 1/4 second. then use the time delay funciton to avoid human hand shake.
You will get high quality piture at night time.
Thanks for advice.
The wheels are off already. It's ready to go guys!!!!!!!
Edited by spikey
  • 4 years later...
    • Been over 2 months since I have done anything on the S15 and had a day off today so got stuck into mounting the radiator and intercooler. I ended up using factory bottom mounts as bolted in and I did order some gktech top brackets but didn't work with the PWR radiator so made up some with aluminium flat bar. Spent way to long on them but pretty happy how they are. Next job was the intercooler. Used some more aluminium flat bar and did the bottom mounts first. Top was easy as just one long piece and 2 90 degree coming off rad support and welded them on. The bumper support required some notching to let the outlets sit where I want so will add some reinforcement later to strengthen it. I have also bought ecu and waiting for it to arrive. Went with a Link g4x Xtreme but will be adding a ptmotorsport expander to add a few extra inputs over CAN. Went through a few different configurations on pclink to get what I want to allow future expansion for sensors and gearbox upgrades. Ordered gktech rear arms but looking at the hardrace lower control arms to have some extra adjustment too will see how the alignment looks after first setup. Got 2 more weeks of work before shut down and will have almost 4 weeks to work on this so planning on hopefully firing up mid January.   Also bought a 2015 brz with a heap of good gear, did noosa hill climb a month back. Owned it for 3 days changed alignment and sent it. Finished the weekend 2nd in class and only .3 off the 180sx best time last year. MCA Red coilovers, gktech rear lca, bolt on lock kit and tie rods, whiteline toe arms, cusco 1.5way diff and 4.5 ratio, endless brake pads, headers, exhaust, perrin intake and e85 tune. Electronic steering adjustment, nankang crs with koya wheels 17x9 +35. Have bought rear traction arm and relocation kit, extended studs and v3 tie rod kit. Planning on also getting flex tune as lucky to get 300km a tank with e85 and short ratio. Car is a heap of fun to drive and super easy to work on. AC in the line up at Noosa was mint in 35degree weather.
    • I'm 22 years younger than you mark, and I'm operating in the exact same way! Ha ha ha
    • All clamps are oem    one question is , what is the bit at the top on high pressure pipe where it connectes to intake manifold and other side goes toward the engine( see item in red circle in diabram attached)   ? Seen some people stating that should be removed on boosted application and skyline is boosted from manufacture so little puzzled. Mine is around 23pwi (700 hpish)   also some state it could be the bonjo bolt crash washer so bought two washers
    • what do you mean dead platform? People buy older, out dated and less power cars on "Dead platforms" for over $65k all the time.
    • That is really nice! Very nice finish when you have an oven to do the crinkling nice and evenly!
