Hi All,
Regretfully selling my Baby ...
Before buying the car and before doing the modifications I took every care in ensuring that what I was buying was of a top standard. Take this opportunity to own a gem that's been babied since being imported. This included getting an Engineer's Certificate as well having CRD perform Compression and Road Tests prior to purchase. Contact me if you have any queries whatsoever. Will be up on Carsales tomorrow.
Notes
· Bought last November, selling due to returning to studies / moving out of home
· Rego Til November
· Engine in good condition, compression and leakage tests were performed on the car by Croydon Racing Developments.. All A1 (documentation available)
· Genuine weekend car. Meticulously Taken Care of (and loved) serviced every 5000kms with Motul Turbolight oil since being imported
· Grade 4 import, all import documents will come with the car
· Comes with Engineering Certificate for non standard modifications!! (excludes POD Air Filter)
· 200rwkw (have dyno sheet)
· Serviced 3000kms ago
Details
·    Nissan Skyline R34 GTT
·    59XXX kms on the clock
·    2 door Coupe
·    Turbo
·    5 Speed Manual
·    XENON Headlights
·    Traction Control
·    HICAS 4 Wheel Steer
·    Power Windows
·    Power Mirrors
·    Air Conditioning
·    Climate Control
·    Dual Airbags
·    GT Wing
·    Keyless Entry
Performance
·    17" AVS Model 7 Rims (With Good Rubber)
·    5Zigen Cat-back Exhaust
·    Blitz Boost Controller
·    FET Turbo Timer
·    Front Mount Intercooler (Croydon Racing) – Near New
·    Monza Racing Pedals
·    K&N Pod Aircleaner – Near New
·    Go-Fast-Bitz Plumb Back Blow of Valve – Near New
·    Professionally Lowered approx 1.5†in Japan
Sound / Security
·    JVC Double Din DVD/CD/MP3 Head Unit
·    Kenwood Splits
·    Powerful Amplifier
·    10†Sony Xplod Subwoofer
·    Upgraded Car Alarm as professionally installed by LifeStyle Store Parramatta
Contact:
Ron 0415556722
[email protected]
See attachments for Photos / Will take more pics this weekend.
$24k ono WITH STEREO, $23k ono without
Thanks
Edited by derek zoolander
Car will come with Stock Airbox (no snorkel), Stock Side-Mount Intercooler ...
Will also consider any trades + Cash Adjustment. Looking for something around the 5-10k mark, something cheap but fun to run around. Preferably non-turbo, manual.
Cheers guys.
Been asked this quite a bit, but I am fairly negotiable on price guys.
Remember the car comes with an engineers certificate for most of the mods plus a very good sound system, so there's no more to spend.
Cheers :)
Hey guys, i have listed everything that I know of.
I was actually quite (happily) surprised too when CRD handed me the Dyno Sheet.
Cheers
Ron
  • 4 weeks later...
okay - haven't looked at this in a while due to being way on business. looking now for quick sale ...
$24k ono with everything
$23k ono without DVD player & amplifier
I am going to sell my Audi A4 1.8T and get a R34 GT-T. I was planning to advertise my car for sale next month when I have more free time.
But, just see if you are interest to swap with an Audi first?
I had a R33 GTS-T about 3-4 years ago and I would like to get a R32/33 GTR or R34 GT-T now. Please let me know and I can provide you more details with my car. Thanks!
Edited by Nismo_R33
    • Have you checked the foam over the years? No deterioration to the foam from e85 mixing in oil? (assuming you're on E85)
    • Add to this... What blew the fuse too? If a circuit feeding power to the coils was blown, how were the coils even functioning to let the car start?   There is some seriously wrong wiring in that car for certain, and I'm betting there is some melted cables somewhere, but I can't explain the 30v either, unless there is something back feeding on that power line that has a dodgy power system and the electronics are giving it hell.
    • This is typically the case with such threads. What I cannot quite get my head around is where a reading above 12V (or 13.8 or 14.x or whatever the maximum achievable voltage might actually be in that specific car) comes from. 25V or 30V should be completely impossible. There's no way to create it. Hard to answer that question. It will literally depend on whether the current tune relies on the values as set. I'd guess it probably does. ie, the real base pressure being 49 means that the flowrate through the injectors will be higher than if it was 43.5. The Haltech's modelling should be handling that, but because it thinks the pressure is only 43.5, then..... I dunno. It should be thinking that it will be injecting less fuel with each pulse duration than is actually happening. So, something is definitely not-as-it-should-be, but specifically what that is is beyond my abilities to imagine. Someone like Dose who spends more time with Haltechs might have a better thought.
    • Bit of a late reply here as me and my wife have been really busy with new born twins. I finally got these issues fixed and it was something really stupid that caused all of this 🤦‍♂️... After alot of mucking around with trying to figure out what is causing these issues, I back probed one of the R35 coils on the power 12v supply, with the engine running it got 25v! And I thought, hang on..., this isn't normal. Measured my battery with the engine running to check for over charge from the alternator and it wasn't that. So then I dissconnected the R35 PRP coil harness and backprobed the power supply on the engine loom where the ignition coil harness connects, with the key on ignition (engine off) it measured 30v! So then I had to trace where that high voltage was coming from and it lead me to the brown relay "ECM & IGN coil relay" inside the cabin next to the ECU on the passanger wall. This relay feeds power to the ECM and ignition coils. Tried swapping it with another same relay. nah still 30v.. coming from the 2 green/white wires in the brown relay. So then I set my multi meter to the beep continuity mode and probed every fuse on the fuse box inside the cabin to try and find this high voltage power source. Wasn't any of the fuses inside the cabin. Then probed all the fuses in the engine bay and BAM, got my power source that was a 10AMP fuse called "ENG CONT". Pulled the fuse out, and what do you know... it was blown. 🤦‍♂️  So then I quickly replaced it with a new 10AMP fuse, started the car and yeah haha [insert extreme face palm]... The RPM blimping thing went away, car idles smoothly now like what it was before. I swear! I checked all my fuses with my test light twice before I created this forum thread. I think, maybe because one side of that faulty 10A fuse lit up on my test light, I must have thought it was still ok and not blown. But now I know to have both sides light up on the test light when checking fuses... I hate diagnosing electricals.... I'd take mechanical problems over electrical problems any day🤣. Drove the car around my suburb with the engine up to operating temp and it runs fine like before. However, I notice that my fuel pressure is still at 49psi. So I'm thinking this must be normal for my system as I've upgraded the stock fuel pump to a Walbro 255L/h with a constant 12v mod.  But anyway, I'm just glad to have my daily back on the road! Thanks everyone for the replies on this thread, all sorted now! One thing I want to ask you tuner guys, my base fuel pressure on the haltech main settings are set to 43.5psi from default (my tuner must have not checked the fuel pressure maybe when tuning my car?). Do I set it to what it actually is idling on at 49psi? Or just leave it ("if it aint broke, don't fix it/leave it")?
    • The max they would go for me is 50.
