Ok guys i have an R33 GTST S1.5
Current mods are
*K/N Pod filter
*Cat Back Blitz Nur Spec R Exhaust........think 3inch
*Apexi AVCR Boost controller
Ok so i think my coils are buggered because if i up the boost to about 11psi at around 4500rpm it runs like crap.....any suggestions?
So the plans are to get a
3inch Dump/Front pipe..........What should i do about the cat?
Split fire coils
High Flow turbo T3/T4 and run a max of 13psi
Apexi SAFC
With this combo should i hit the 200rwkw mark
Now on to my next question
Where in sydney should i take it to get a tune......need cheap and quality
Regards
Mick
https://www.sau.com.au/forums/topic/177283-sydney-dyno-and-mod-advice/
i was making 204 rwkw with the following
- turbo back exhaust and high flow cat
- pod
-avcr (.95bar)
- fmic
-stock turbo
its a good tune that will make the car just as long as you have done the basic mods.
put in cam gears and pfc and made 224rwkw at .95bar
damn....sounds just like mine..
i have turbo back exhaust, fmic, pod, profec ii at .85 and stock ecu and made 202.6kw....
so you only put cam gear and pfc and made 224 of stock turbo at say 13psi?
Maybe i should invest in pfc....
hey simon that rb20 ecu is really interesting........how much does a full remap and tune cost for one.?
also if i just plugged in the 20 ecu would the car run as normal or needs to be remapped first>?
you should think about getting the eeprom copied im sure alot of people would be interested in buying that....
Mick
Edited by MrMike
Mick
The Map is not mine to sell, Mate of mine does the tuning for a reasonable price either way :banana: See my sig for details for The Speed Lab
As for the ECU, it is plug in and the car will probably start and idle but it wont be driveable thats for sure (rb20 has smaller injectors) so your best bet would be to leave the 33 ecu in there and drive to the tuner. Or get the 32 ecu epromed, buy chip from TSL and plug it in and drive it, Would be best to get it on a dyno to check everything before you really drive it hard tho.
As for price, ECU cost me 50 and the mapping/dyno time averages around 300-400 including chip install
I have a series 2 engine in the car will the rb20 ecu still work? sounds like a much better investment than the safc 2 i just bought. apparently the safc2 i bought has a 192rwkw tune on it.....how safe is it to run that tune on my car......
I have a diagnostic tool that i can monitor the knock signal and rich/lean mixtures while driving......if i have no detonation or continual rich/lean running .......it should be alright yes?
:D
    • The NZ wiring kit is a 1/3 the price and will be perfectly fine for your application, I've ran one for 6+ years and many others have. Comes as a full plug into factory connector and the settings for a Link. https://www.nzwiring.com/index.php/product/trigger-kit/ Always comes back to the tuners knowledge and experience with a tuning platform. It takes years to become proficient and learning all aspects and capabilities. I've been using Links for 16 years now (rb and sr paltforms) and always learning something new with adding tables, diagnostics and data logging. Stay 98 for the usability and keep it simple so you can enjoy the car more. With experience I'll give you a current example of the industry I am in. They use Motec m190 and only use VE tuning when they have a torque mapping available and would solve the "PARITY" issues that plagues the category all because the muppet doing the tuning doesn't understand the platform or want to learn it and the product seller have no idea on its full capabilities ( I had a good laugh as when firing up an older car that just got completed and they didn't understand the injector scaling or how to change it for different fuel being used)
    • I'm sure there are specific hygrometers for it. But if you can just throw a high enough ranged temp sensor (theromcouple that came with your DMM, for example) into a pot of it on the BBQ, you can see when it boils.
    • I have multiple bottles in a shed that gets hot, and I'm in SEQ, so it's humid. Maybe we test their theory... Anyone have a system to accurately measure moisture content in oil?
    • Yeah, that and throwing away opened, part used, closed back up bottles has got to be bullshit. Brake fluid sits in not-very-well sealed master cylinder reservoirs for literal years and keeps working (albeit we know we should flush it every couple of years - it actually still works). Anything kept in a bottle in the shed with a tightly capped lid has got to be a million times better than what has been in the car for the same length of time.
    • Wait, they're claiming UNOPENED fluid has a shelf life of only 18 months?
