We need to start a thread about common problems so we are aware of them when they arise.
Does any one know of any common problems with these vehicles?? E.G. TRANSMISSION, ENGINE, A/C, ELECTRONICS ......
I Don't know if you guys have had the problem, but i have read forums in the U.S. where oil consumption with some g35 and mostly 6mt, seems to be a real issue. Infinity if pushed, has replaced engines.
Does anyone know for sure if the g35 is made in Japan or the U.S. because i was told this was a U.S. problem?
What do u do if the key fails?? how do u get in the car?
Oh and has anyone found a workshop maunal online?
If I am correctly thinking of the manual you are talking about, there is one on www.g35drive.com. http://g35driver.com/forums/showthread.php?t=107032.
awesome thanks mate... also when u pulled ur ket apart was there a metal piece floating around freely... i couldnt for the life of me work out where it was supposed to go so i left it out my key has double the range it used too...
My drivers side power window switch is starting to work only when it wants...
You will need to replace your window electric motor available from Nissan @ approx $350
I've had to replace both now
They also seem to have issues with clicking rear wheels
Welcome.
lol, nah, I didn't have anything like that. But hey, as long as it works, and it seems it works even better now, haha. My range isn't very long, so wouldn't mind the double...
What you mean clicking rear wheels? What is the actual problem?
I am having problems again with my central locking and power window both on the driver's side. The auto electrician who knows the V35 repacked the power window motor and aligned the gears and it worked for a while but has now shit itself again.
Any clues why both have gone - do they use the same controller? Are the motors for both the same as the 350Z?
The window is locked in the up position and it interfers with the top moulding when closed because the release memory for the window to open and close the door is also not operating. Any clues as to what's happening??
Unfortunately seems to be quite a common problem. A few of the 350z guys have reconditioned the power window motor but also didn't last long so they just go out and buy new motors. Best price I've seen is $500 for both passanger and drivers side. Not sure why it would interfere with the central locking though.
Here ya go Dave
http://www.infinitihelp.com/Ownership/Bull...5/ITB05-002.htm
Main page for any other problems
http://www.infinitihelp.com/Ownership/Infi...35/Diagnose.htm
Cheers
Chris
  • 1 month later...
I've been searching for info on V35's to replace my ageing POS 1994 Maxima.
Window failure in a Nissan again! I thought they fixed this problem, how the hell do they manage to replicate it again? :P
The window motors in the Maxima have been replaced by an auto elec, after Nissan charged me $200 just to look at the car. All up has cost me $500+ and they still don't work!
The back rear window is chocked up with wood, which is very stylish.
The front windows would not come back up so I reversed the polarity and used the door entry keypad to wind them back up then disconnect the power all together.
Basically I don't need to deal with this f**king bullshit again in another Nissan.
Anyone actually had someone fix the windows in the V35 and have them stay fixed before I even think about buying a V35?
Is the same problem in R33/34s or just the V35?
    • Is there a way to adjust all of the pedals in an R32 GTS-T? they all sit even, but seem to be a little high for my liking.
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
