From what I've read, it's luck of the draw. Some have had the car for years without a problem others have bought brand new motors and have had probs again. It's definately not a problem with EVERY car.
My opinion is that every car has it's issues. The good thing with my experience with Nissan's is that the issues are generally not thousand dollar issues, and more little annoying things.
In the end you get what you pay for. People sometimes forget that the V35 for what it is, is a very very cheap car. Similar performance, similar looks, similar equipment in most other cars, and you'll be laying out $100k.
Iam in the process of purchasing a V35 from Japan, do they come with factroy keyless entry ? if so a people has mentioned that the keys has stopped working is that the remote ? also people mentioned what happens you cant get a car if your keys has stopped working isnt there a hole to insert your keys into ?
yes there's keyless entry
mine has worked 100% fine every time so far (about 2-3 months)
there is a key hole if it doesn't work, but mine came with 2 keys (with remotes) and the valet key so its not like you're going to be left stranded you will have a backup
don'ts worry mate - the V35 is a treat of a car!
Yep, I own it for more than 1 years now. when I purchased, it is alread more than 34000KM. I believe it is higher than anyone else here. but I had never have any problem. Trouble free and stylish car. I am pretty happy with it so far.
i also got two original keys with remote.i also got a third marone/red coloured key.
is this the valet key or the master with which to cut new ones from.?
i only ask as my old honda had a red master key ,which if used to start the car it would render the car undriveable!!!
red key is the valet key
it opens the doors and starts the car only, ie if you're leaving the car with someone else
has no alarm function, won't unlock the glovebox, and in other cars that have a boot key hole it won't unlock the boot..
i use it when i take the car to the carwash
Hi, this is one for the V35 6MT guys, have any of you guys had problems with the clutch being noisey or having clutch chatter or vibrations through the clutch pedal? I've read on the G35 forums that a lot of the 6MT guys have this clutch noise or chatter problem.
cheers
  • 3 months later...
My drivers side window doesnt go up sometimes! I can hear a relay clicking under the switch box but thats about it. Then it works again sometime later.
ANNOYING!
JK
Yes, this problem is very annoying. However, I can confirm that the 'tap' works. My sparky told me it happens in some cars and may eventually need to have the motor replaced, or it could be that the window gets dirty and causes it to stick. I have noticed that my windows have been dirty evertime it happens - may just be coincidence?????
To open or close...... simultaneously, hold the relevent window switch (up or down) and give the door a 'fonzie' on the inside door panel - has worked everytime for me so far when I tap the top of the door panel.
For those who are too young to know who fonzie is, forgive this old bastard and, just 'give the door a slight thump with your palm' :banana:
Cheers,
Vic
My v35 has just clicked over 50 000km, bought it a week ago, so far no major problems however fule consumption is up around the 14l/100km with mostly highway driving. This tank looks like the consumption is getting worse. Also noticed that the car seems to be sluggish sometimes with seems to be coinciding with when the car has less than 1/4 tank of fule left. Im hoping to get my hands on a scanner to take a looksy to see if i can see any problems with it.
Other problem is the light between the sunvisors some times dosent work on one side, but a good tap seems to fix it.
Ill be sure to keep you guys posted whith any other problems i come accross.
  • 3 weeks later...
Hmm just wondering with this clicking noise.
Is it different to the clicking noise you get when the rear pads are really low ?
Yep, it's a known fault on the rear axle. Usually on the right side of the car.
have u guys had any luck getting this fixed? if so how much did it cost u? I mean it's no big issue, js make the car sound cheap when u have lose metal sound clicking everytime u change gear...
I had the captive bolt that holds the shifter fall off. I replaced it all with a short shifter in about 30mins. The shift distance is about half what it used to be. Best $100 I ever spent.
Hey mate,
which kit did you use?
There's a few discussions in the US about certain kits being terrible.
  • 4 weeks later...
just a question regarding the engine. say if you were to Twin turbo it, would that bring it close to the new VQ38DETT in the R35GTR? as the difference is only .3L
Just weighing up the option that's all!
in terms of power? i believe a TT 350GT can generate about 400-500hp depending on the kit. but performance wise it will be nowhere as good as the GTR...
you can give it a great bit of performance with a TT or S/C kit, make no mistake (have a good read of g35driver.com - there is a whole forced induction section)
but the VR38DETT in the GTR is a completely diferent engine, with many parts that are unique and make it as good as it is. plus the car is a whole different beast - AWD, bilstein suspension, etc etc
you can never make a GTR out of a V35
but if you have realistic expectations, you can make one very fast and awesome looking V35 that is good in its own right!
    • IMG_8641.mov     She doesn’t sound the best but starts with out using any gas now. I just ran some injector cleaner through her. started roughly the first time after adding it but gave it the beans slowly upto 4k, Must have cleaned a few cobwebs out. another step in the right direction for the sub
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
    • How much does the shifter move when the car is in gear with the engine off? If it is more than about 1cm you need to replace your shifter bush. Your shifts will just get crunchier, not faster, with a short shifter unless you also rebuild the whole box
