  • 1 month later...
Mine use to do the same thing. Until I replaced it. Common fault. About USD$200 for a new motor. Easy to install though, dont have to take the window regulator out, it just bolts to the exterior of it between your door skin and door frame. 5 minute job.
JK
I'm a bit stuck! at the last bit!
I've taken the door shell everything out incl glass and remove the 3 bolts that holds down the lock actuator...
found out that it's also attached to a catch behind the door handle and I can't remove this. is this require removal of door handle? anyone done this before please let me know...
I found one * bolt behind the door handle but after I remove it - the door handle still won't budge/pop off from its shell.
EUREKA!
Don't worry about it...
After thorough investigation managed to find the other hidden bolt !
I've swapped my lock actuator and it works great! Took me about 4-5 hours to get it all done.
I will write up a DIY as I've taken lots and lots of photos...
STAY TUNED!
My DIY on window regulator/lock actuator removal is done!
See here!
Door Lock Actuator Removal - DIY
NOTE: DO NOT TRY THIS if you're not game enough with tools, potentially scratched skin, or if you are short tempered.
I am not responsible for any direct/indirect damage or injury done to your car or any persons from following this DIY guide.
  • 9 months later...
Hey guys!
I've given this a search here and only found one post about it, that no one answered.
For the last month or so my clutch has been making lots of noises, like an old creeking door!
Also when pressing down on the pedal as a result of the sounds you can feel that it is vibrating, almost feels like it is sliping.
I had it at Nissan while it was being serviced recently and asked them to assess it, they told me nothing was wrong with it, wasn't worn out of anything, and they couldn't replicate the noise. Typical of them! and strange they couldn't replicate the noise it as it does it ALL the time and is very loud!
Anyway, if any of you have had this issue and know what it may be please let me know.
Cheers!
Hey guys!
Cheers!
I had this, i just flushed the brake fluid with penrite sin 600 and adjusted the clutch bolt and its all good :) I even made a video showing the noise, cant remember if i posted on this site or G35...
  • 4 years later...
  • 7 years later...
  • 2 months later...
On 29/07/2007 at 11:17 AM, R34 said:
You will need to replace your window electric motor available from Nissan @ approx $350
I've had to replace both now
They also seem to have issues with clicking rear wheels
Clicking wheels.
Purchased my 370 a couple months back front right wheel was clicking like a b**ch under load ie left hand corners. Thought it was a bearing problem turned out to be minute amounts of movement between wheel and hub. Solution - wire brush clean both surfaces and reassemble with a small amount of grease. Problem solvered.
*Note to other newbies like me. Always use correct wheel nut socket (6 sided) as opposed to 12 point deep socket. Wheel nut is actually two piece with a chrome plated brass sheath which will spin on the nut if incorrect socket used. Absolute nightmare to remedy involving much tapping, flattening, coaxing hammering and swearing.
On 11/13/2022 at 2:58 PM, nicko370 said:
Clicking wheels.
Can you elaborate on that? Any photos?
Stock wheels or others? It makes no sense.
This sounds like the old 'rear click' that the 350Z/V35 had, due to slight bit of movement between the rear hub and drive shaft under acceleration or braking.
https://www.notre350z.com/forum/files/uploads/dold/1207422654_ClickClack.pdf
Never thought it could be an issue between the wheel and hub though, if the wheel nuts are properly torqued.
Edited by sonicii
Yeah who knew?  Mot me. But the mechanic at Tokyo Prestige was straight onto it. Whipped the wheel off, smeared a small amount of grease on the mounting surface, reassembled with wheel nuts done nice and tight, no more clicking.  He suggested removing all four wheels and wire brushing the whole lot for good measure just to ensure there's no crap in there preventing a true mating surface.  Wheels are stock. The noise was very noticeable.. cornering at speed, sounded like a stone or tek screw caught in the tyre. Low speed carpark manoeuvres it was a metallic creaking or clicking sound.
Interestingly I am now noticing the rear drivers wheel is also doing it. I haven't tried the clean and grease remedy yet will be interesting to see. Haven't had a chance to read up on it yet.. lots to learn on here.
Props to the guys at Tokyo though.. service with a smile and no charge for the 10 minutes he spent mucking around with my car.
  • Like 2
  • 1 month later...
Strangely, when I had to swap out a flat tyre out driving a couple years ago, my wheel brace needed to be hammered onto the wheel nuts in order to get a grip of them. Turns out the nuts were all slightly larger in size, which explains why I managed to destroy one of them later when torquing it up with a 12-point Kinchrome deep socket and breaker bar I bought to replace the stock wheel brace.
I never noticed this at home with my impact socket and rattle gun, other than me thinking that perhaps the socket itself was a bit on the tight side. I've since replaced that fancy deep socket with a regular hex socket to avoid such situations out on the road. The things we learn!!
A bit of nickel anti-seize compound that I've used every time I do any refit of any wheel has always kept me out of trouble with both my vehicles, though after reading this, I didn't realise I'd also be avoiding any odd clicking on the V36!
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
