Everyone that has a 2003 coupe might experience this.
I started my car this morning usually let it idle for 5 mins to warm up.
When i took off doing under 10km/h the car changed from 1st to second. I got this grinding/ recoil noise from the front. After that it didnt happened. I stopped and tried it again nothing even when changing gears on the highway.
Second time started it up after 5 hours put it into DRIVE, drove under 10km/h changed 1st to 2nd same thing grind for a split second then nothing.
Im a member of the G35 club in the USA, asked them questions and there were even threads regarding this matter. Apparently its the ABS initialising and doing a check. Some of the guys own 05, 06 & 07 models. They said it happened to theirs after only having 1000km/h on the clock. So it must be the ABS checking. There are probably a dozen threads on this problem and all the guys said its normal. Anyone experiencing this?
Yep, got the same thing in my 05 Coupe.
Was a bit worried the first time I heard it, but then as you said noticed it was only doing it when you first drive after start up, so I assumed, don't laugh, it was some sort of pressurising of the brake fluid, in the lines.
Good to know it's normal :-)
Yeh, That is ABS test or inital something.
If you are luck put your food on break pad at the same time (Just like me when i approch the garage door ) you will fell the pad same same respond as ABS break kick into in hard breaks.
That is common take it easy.
Coming to think of it and describing the exact noise i wound't say its a grinding noise. Think of a spring recoiling thats what it sounds like.
Yep normal it is even mentioned in the owners manual that I got with my car. It was printed by the company that complied the car.
I don't experience that.... hmmm. Maybe thats cos I have reset my ECU cos previously all warning lights used to come up... Since then, I've experienced little any electronic intrusion compared to before when my VDC used to cut in.
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
