Hi guys.I already use search but I could not find result.Can you please advise.I put r32 actualator on r34 gtt .And under 3 rd gear I think when full boost it miss a bit and come back.Anyone know how to fix this and how come it miss because r32 actualator it run on 10 psi .It should not misfire.Please me and advise thanks
https://www.sau.com.au/forums/topic/177318-r34-gtt-miss-uder-boost/
it could be a number of things. you could try regapping your spark plugs that might help. I think the most likely thing is the ecu is setting its self on R and R. Because that was happing on my car as soon as i put it on 11psi and i was told unless i change my ecu to keep it at stock boost.
Thank you
