How Much Do You Spend On A Oil Change ?
Ok than i guess i will start to rip half the dash out to double check things. Thank you gtsboy
Yes i changed all the wiring,dash looms wiring from the ecm and tcm. Installed the tiptronic cluster, ecm, shift controle module even the tiptronic shifter. Only switch that i do t have is the steering wheel switch.
By svenskalice · Posted
Yeah, true. Still sucks it lasted so short though, was planning to drive on it for another year or so. -
DB1520 is correct, Brembo pad for both the 350Z, GT-R. DB1170 is not correct, they are for Sumitomo calipers, found on the R32 non V-Spec GT-R, and GTS-t, GT-t Skyline. -
Yeah., so whilst the death of that one was actually caused by other factors - it's still a 30 year old turbo. It's alrwady had a life. There are no new ones.
