I personally wouldn't spend too much on a Cusco cage if adding bars, if you wanted something better, particularly the front legs I would sell that one and buy a Bond one (under $1500 for R32). They do a harness bar and diagonal in the centre hoop and are CAMS approved.
The removable Bond ones are constructed of mild steel and Cusco are chromoly from memory.
I had a bolt in one from Maitland Fabrications in my GTR... would always weldin now, but thats not practical for some people.
Edited by t01-100
thanks for your comment,
I didnt spend that much on the cage, i bought it second hand, and weld a bar through the main loop and perhaps a harness bar between the rear legs is not going to cost much at all, about $150 for both.
But I though id ask if is going to help strenghten the cage or is just a waste of money and time.
Cheers
Ric
a diagonal in the centre hoop will certainly help stiffen the car and would be handy if the car was turned over.
the R32s that I've seen doing track work with R tyres without front legs usually highlight front chassis flex by popping dash vents and or cracking windscreens!
Gimme Chromoly anyday over mild steel for a roll cage.
Chromoly can be a bit of a bitch to weld sometimes.
actually nearly all the cusco/safety 21 cages are steel, not chro-mo. though they do have some models available in chro-mo.
I have a cusco 8 point which has a horizontal bar between the rear legs (above the strut towers) and has a diagonal bar running from the top of the hoop to the strut tower.
Mine is the same but doesnt have the horizontal bar between the rear legs (harness bar), thats one of the thing I was planning to do to it.
Is it better to weld a horizontal bar through the midle of the main loop? , or is it better to make it a diagonal from one top corner of the loop to the bottom of the opposite corner? If that makes sense..
Cheers
Ric
Cheers
Ric
Mine has the diagonal from the top corner to the bottom of the opposite corner (but going from hoop to strut tower. So the rear half has the main hoop, two straight legs going back to the strut tower, horizontal bar between those two legs, diagonal from hoop to strut tower.
    • It only looks tidy, as most of the stuff that was on the whole back wall, is now in the trailer to go to the tip, or has been shoved in my 2.2x2.4m "Spare parts room", and now I can't get to anything in there Ha ha ha I could definitely do with a bit more space, but I'd just end up with your problems I'm going to enclose the car port beside the garage, and move a lot of stuff into it I think. OR... It will be setup as a fabrication area, and the main garage will have parts storage in it. I'm not sure yet... Need some pictures of that big shed you've got with the bikes and Skyline in
    • No. I think it's gone. 😭 I think you can get body coloured ones on eBay so I think I'll get one of those... Or just hang a red ribbon from the hole and whack a TOW sticker next to it.
    • Can't say I've had a bad experience with one on my car, then again it only gets washed once or twice a year... The wheels on the other hand, get a good spray often due to my shitty dusty pads.
    • @MBS206 thats pretty neat and tidy to me!  I'll get a photo of mine when I'm out there next. It might require multiple photos to understand the scale of the atrocities though... In total I have 4 sheds of varying sizes and layouts. Main shed is 14x8, second shed is 3x8, third shed is 11x2.5, fourth shed is around 6x4.  All are pretty much full.   The main goal of my cleaning tsunami is to make the main shed predominantly car and motorbikes only. Second shed is my metal fab room (2 x bench grinders, drill press, bench belt sander, metal band saw, scrap metal storage and some of my garden tools.  3rd shed is more bigger garden stuff, storage for engine crane, jack stands, concrete grinder, concrete mixer, air compressor lives there, and it now has two 2mx2m pallet racking shelves with itemised boxes holding building stuff, electrical stuff, plumbing stuff, etc, etc.  The 4th shed is Ryobi electric ride on mower, mini boom sprayer, ancient Kubota tractor, more garden stuff!  I have got a lot of shit....  Then there's the pool house (8mx4m) and the pool pump shed (4mx4m).  I built all of the sheds over the 11 years we've been here.  The main shed was a Ranbuild kit, the rest are all custom made to fit the areas available. Building the main shed taught me a LOT as I had no idea about building anything prior to that!  I've still got one more in me. It will be my man cave which I poured the extra concrete for way back when I poured the concrete for the main shed. The idea is the Skyline will be a centre piece of the main cave once (if...) it's finished.  I told my now 14 year old son yesterday that I will 100% drive him to his year 10 formal in 2 years. Still a long way off but at least I now have a date to work towards! 🤣
    • Modern oils are amazing. Add tyres to that as well.
