ive got my head unit up and running, except for the antenna. when i connect the blue wire for the antenna to the red/green wire, nothing happens. when i connect the blue wire to the red/green and the red/white wires next to it, the antenna goes up. when i connect the blue wire to just the red/white wire, the antenna goes down.
im stumped. can anyone help me out?
https://www.sau.com.au/forums/topic/17738-wiring-my-power-antenna-on-my-r33/
antenna goes up and down each time 12v is applied. If you connect it to the accessories, or battery wire it will go up and down yes each time u connect it.
When i can think i'll get back to you :P Not all stereos have the antenna function..
The antenna only requires 1 cable which off hand is the red white.
Connect your blue (remote) wire on your deck to the red white. Turn the deck on anttena should go up, turn it off and it should go down.
Works like a charm in my R33.
I think the red/green is actually your instrument lighting too.
The factory headunit would only put the antenna up if you were using the radio feature, if you were using the tape feature then the antenna went down.
When I had my new headunit installed, regardless of whether I was using the cd feature on my headunit or the radio feature, the antenna stayed up. It only when down when the whole headunit was powered off. Very annoying
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
    • I don't think it's a good buy, the trend looks bad     lol.
