1989 R32 Four Door
Type M body Kit
RB25DE + T with 1.8 mm cometic metal headgasket
Apex Power FC
Turbo Injectors
Intercooler kit
Alloy Radiator and twin thermofans
New Thermostat
Drift Pineapples
Whiteline Swaybar
Tein Coilovers
Cusco 2 Way diff
Steering Rack Spacers (extra lock)
Hicas Lock Bar
Exedy Clutch
Work 17 x 8 and 17 x 9 low offset dish rims
Brand new federal steer tyres.
Stainless Exhaust
Dump Pipe
Good Interior
JVC MP3 player Headunit
Possibly could be used for drifting.
Looking for 12k ish with Rego and RWC
located Gold Coast
Cheaper if unregistered.
Offers welcome. No offense taken.
Text or call on 0418 720 513
PM also welcome
Edited by andylaurel
https://www.sau.com.au/forums/topic/177389-r32-4-door/
How much unreged?
Also, Ks on car, when was the engine done, any shots of the interior, manual or auto and what gearbox if it is a manual also what turbo setup on the car?
https://www.sau.com.au/forums/topic/177389-r32-4-door/#findComment-3240357
its an RB20 manual gearbox
km on car is like 120 000
its a 1995 motor from the wreckers with even compression, estimate around 70 000 km
turbo setup is all standard RB20 stuff
make me an offer unreg
https://www.sau.com.au/forums/topic/177389-r32-4-door/#findComment-3241298
Can you send some pics of the interior, boot and enginebay?
Im in Melb so a little hard to come check it out.... so the more pics the better. (inside and out)
emails [email protected]
https://www.sau.com.au/forums/topic/177389-r32-4-door/#findComment-3241385
Thanks for the interest Inark and Colleen.
I will try and get those photo's by tonight for you guys.
oh and thanks anyway to the swappers, but no swaps please guys
i'm selling with the intention of freeing up cash for an investment.
PS the car was in Drift Battle Issue #19
https://www.sau.com.au/forums/topic/177389-r32-4-door/#findComment-3246409
'Possibly could be used for drifting'
LOL
Quote's from Drift Battle article:
'A regular on the Gold Coast drift scene,Andy's been working the tail for several years now.....'
'All were driven exceptionally hard, and for the R32, life is no different'
'As you can see from the images, the '32 has no problems with hanging the tail out....'
Bump for a tough 32!
Goodluck with the sale buddy ;)
https://www.sau.com.au/forums/topic/177389-r32-4-door/#findComment-3259616
lol yeah unfortunatley with the expiry of my original RB20 shortly after buying this car, it hasnt seen much drifting whatsoever.
its all there though.
all you'd need to drift it is money for tyres and talent.
ps im sorry i havent been able to get any more photo's.
its been a combination of me having to study for marketing exams, my lack of access to the workshop and my inability to find my bloody digicam.
https://www.sau.com.au/forums/topic/177389-r32-4-door/#findComment-3262148
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
