Hey all,
I posted a topic on here a while ago asking advice on what kind of mods i should get for my r33. My car already has an Apex 3 inch exhaust, blitz FMIC and high pressure fuel pump. After a lot of deliberation, ive come to this list, written in order.
1. K & N panel filter
2. Apexi Powerfc (with or without Handset?? advice??)
3. Bigger Injectors (im guessing around the 500cc mark?? or 740cc?? advice again??)
4. Then from that, id say camshafts??
5. Bigger Turbo
Im aiming at around 200 rwkw (at least) on stock internals. This car is also going to be a daily driver so i dont really want to dial up the boost much if at all. I basically want to get as much power as i can safely out of the stock internals.
Is there anything i have missed out in this list?? And finally, how much would this list cost me roughly all up?? including a proper tune and labour to install etc???
I know these are pretty novice questions, but any help would be much appreciated!!!
https://www.sau.com.au/forums/topic/177404-noob-questions/
1. Filter not too expensive about $80 i think
2. Power FC. If you can find one, buy it. They are around $1K
3. Bigger injectors are good, 550cc would be the mark. You wouldn't have to go to 740 for 200kw. Not sure on price
4. Cam shafts, good idea, pretty expensive tho
5. Again, expensive. Look at some high flowed turbos. Slide has some (trader on sau)
https://www.sau.com.au/forums/topic/177404-noob-questions/#findComment-3240465
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
