I think they look pretty good. Finally Australia is producing cars that don't simply look like blobs with too much plastic, and yes I did see the plastic around the headlights.
If I were to be given one of these cars or something with the same power from Germany, I would definitely go for the German product however if I was buying it I would most likely be paying 2 to 3 times as much.
Pretty good value for money I say.
Looks good, I like it.. Always liked the now older style F6. The enw tornado would be awesome.. factory 300KW ute with turbo goodness! Someone mentioend power to wieght, that GTP would have a hell of a lot of torque on it. never driven an aussie muscle car but u'd expect if they r selling them overseas, america and the UK, where 'real' muscle cars r really built then they must be pretty decent. Actuall sucks to hear about the commodore GTS-R.. Taken a great name code from the HR31 and made it into a f**kin banana! Would be interesting to see the new one tho and read about it. U know its going to be a good car. maybe the current F6's will come down in price from over 50k second hand.
Liam
Throw some boost into the typhoon. :)
Apparently i heard those XR6Turbos are only running on 4 psi! And they have a Garrett GT30 turbo or something like that? Not quite sure on that but i reckon if they run them on 14psi boost, lightly modded GTSTs will not be a match for them. :P
You sure heard some wild rumours. Also Lightly modded GTST's are already being thrashed off the line by lightly modded XR6T's. Driven a liughtly modded F6 and loved it. Still nothing compared to my GTR :)
Just a quick note on the subheading of this thread...
HSV finally has some competition from the Blue Oval
The turbo six-pots have had it all over the GTS, R8 etc for a very long time, champ.
Apparently i heard those XR6Turbos are only running on 4 psi! And they have a Garrett GT30 turbo or something like that? Not quite sure on that but i reckon if they run them on 14psi boost, lightly modded GTSTs will not be a match for them. :laugh:
man even lightly modded gtst's wont have shit on a stocko F6... until you start changing turbos of course
the xr6t currently run 6psi. the new f6 are going to be running about 11psi. the current f6 run about 9.5psi.
my brother in law has a ba xr6t. his made 248hp (185kw) at the wheels (100% stock). he has put a flash tune in (just an of the shelf one, not tuned specifically for his car.... yet) and pumped it up to 12psi and got 299.3hp (223kw). that is with standard exhaust, standard airbox and filter, and standard intercooler. he going to get a new airbox, intercooler and injectors and get the tune done for his car.
also the sound of the big six hitting the traction control is awesome.
a mate of mine has a xr6t. he has spent a fair bit of money on it (it developed an electrical problem when number 1 piston came out and destroyed the alternator). he had a full forge rebuild, c4 gearbox, and now he needs the diff done. on a light tune on the stock turbo at 18psi he made about 410hp (305kw).
as for the hsv gts-r i didn't think holden had decided if it was actually going to make it yet. and it takes them 7.0L to get 365kw. they have to use big cubes to get the power. atleast ford is getting 320kw out of only a 5.4L
too big, too heavy, and they use too much fuel...
i wouldnt buy one when i know that a japanese turbo car can out handle, out brake, and out accelerate for less money
unless you are talking a gtr or a fairly modded gtst they won't out accelerate a turbo xr. if you honestly think that you need to spend more time at the drag strip.
and as for handling, have you driven one? if not, then what are you basing it off? or have you driven an early e series falcon and are basing it off that? i know round where i live, where the roads are crap and rough, they would out handle a skyline cause they soak up the bumps beter.
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
    • The only high-power RB I've personally seen go pop after running for all of an hour on a dyno was built by B2R, while being remotely tuned by B2R. The only wastegates I've ever had leak like a sieve, return, still leak, return and get shipped back the wrong ones were from Turbosmart. The only final drive that I've ever purchased that were unusable, twice... were from Speedtek. The only seat mounts that I've ever purchased that placed the seats in the door frame were from Crank Motorsport. The only poorly designed parts that I had the manufacturer confirm should have been designed as per what I mentioned were from GKTech. The only ECU I've had firmware updates consistently break things are Haltech. The only catch can I've purchased that didn't fit in its advertised spot was from ATP. So forth and so on... Moral of the story, doesn't matter where it's from. Do your research beforehand and stick with products and companies you've trusted in the past.    @joshuaho96 If you want it done right, do it yourself.
    • Something coarse-ish. 180 is good.
