Landed in June, complied in July and had her first Aussie number plate this week.
GTR R32 1994 - And shes booooooooootiful (I'll admit to being a little biased at this point).
I've tried updating my profile and managed most of it okay, however cannot see where I can edit the RB20DET bit on the left. Can someone please tell me where this part lives?
Cheers
Michele
Edited by LadyBytes
https://www.sau.com.au/forums/topic/177432-new-baby-has-landed-baby-gtr/
Congrats michele! did u import thru a broker?
He is an importer/dealer, although I didn't order from o'seas, it was here and complied when I bought it. Its seriously clean, had low k's (57000) which I didn't believe for a minute, however the inspections I've had since seem to support that the k's may have been original. If thats true, then I'm impressed.
Now its time to do my own mods, I've been talking to Trojan and they said I should start with HKS-GTSS Turbos $4000 + Fit $2200.
They pulled the little restrictor out of the boost control (is that what that part is called?) which I understand is compulsary in Japan. I thought it was a good sign that this was still in place.
Slotted rotors, a stronger clutch... OMG maybe I should have bought that heavily modded car in Sydney after all LOL ahh well, I least I know this one has been cared for.
Edited by LadyBytes
Congrats on the pickup.
As you've probably been told the RDA group buys are excellent value (nearly 1/2 price of what I was quited in Canberra, which was way above retail)
Jim from Brisbane does make a good clutch, I've got one.
The GTSS turbo's are great turbo's if you are going to limit the car to 300rwkw, I went the 2860R-5's and should have the results back this weekend (should have been last weekend) thanks Croydon, they can make it up in the bill.
Other mods to consider
Boost controller
New ECU
100K service, replace belts etc
SK's suspension kit
new cams
adjustable traction control
injectors-fuel pump
and a gold GTR key found in the group buys
Well that's my current wish list :D
Edited by a20089
very neat ride. are they V-Spec II wheels?
VOLK RACING GROUP A EVOLUTION 2 17" X 9" MAGS
Not a lot else done to it
KAKIMOTO STAINLESS STEEL RACING EXHAUST MUFFLER
TEIN ADJUSTABLE COILOVER SUSPENSION
NEW FALKEN 235/45ZR17 TYRES (which are harder than I hoped/expected, but perhaps I'm spoilt with the Federal 595rs's)
HKS TURBO-TIMER
and thats about it, the rest is up to me.
If u got the cash get the turbo put on , but i think it would be wiser to built up the supporting mods first so u get the most out of the turbos.
If i was u i would get (approx prices)
*remove hicas $400
*adjustable cam gears $400
*power Fc plus tune $1500
*a good EBC $500
*oil cooler $1000 (if u are on the track)
*injectors-fuel pump $1400
*adjustable control and castor arms front and rear $1100
but this is just me , dont flame me about the prices it just off the top of my head
It a really clean looking r32 well done
*remove hicas $400
*a good EBC $500
HICAS - wouldn't remove it unless you find it hinders your driving.
Cam gears are a good idea, no ideas on price.
Power FC and tune great, might find it costs $1400 for an "Australian" delivered version or wait weeks from other stores.
Electronic boost controllers are great if pushing more than 1 bar/14.9 PSI $500 will get a cheap one plus fitting costs.
Oil cooler and filter relocation are great improvements if you do track work or service the car yourself, remember to get a thermostat controlled one in Canberra else your oil temp will never raise to operating temperature doing general driving in winter. about $1500 installed
Injectors and fuel pump if chasing more than 300rwkw, $1700 I was recently quoted but the fuel pump fitted $700 seemed a bit pricy to me
Not bad on the prices GTR32GUS :D
For the RDA buy, just look in the group buys section in the forum, it stands out somewhat
Edited by a20089
Now which ones
Grooved & Dimpled Rotors:
7. R32 GTS-t/Z32 300ZXTT: F=909G 280mm RRP $305, R=908G 297mm RRP $285 (Front can be used for S15 Silvias)
8. R32 GTR (early models): F=7926G 296mm RRP $440, R=908G 297mm RRP $285
9. R33 GTS-t/R34 GT non turbo: F=7693G 296mm RRP $465, R=908G 297mm RRP $285
10. R32 GTR (late model)/R33 GTR/R34 GTR: F=7701G 324mm RRP $575, R=7702G 300mm RRP $525
I know there is a size difference, can anyone tell me why/benefits?
do u have brembo brakes or just the standard nissan one
The 324mm rotors are for the brembo brakes
The 297mm are for the standard brakes
Thanks, I thought it may have meant
F=FRONT
R=REAR
I imagine prices quotes are for a pair... or is it each?
    • Unless you have big cams, there is no reason for an RB to idle at any more than the stock 650. No, it is not 850, 950, or anything else. It is 650. In fact, it might even be 550. I just opened an arbitrary stock Neo file in Nistune, and this is what I see
    • I love the undertray, especially the flappy bit for easier access for serving I'm thinking of fabing up one at work for the MX5 while I still have access to the metal shop at work with a guillotine and press brake Whilst removing the plastic undertray on the MX5 isn't to hard, I love the idea of a 2 bolt flap as opposed to removing the whole thing
    • Great thank you for that. Yeah that is the bumper and spoiler it still has i just hadn't heard of it being referred to as a aero form bumper before. Really appreciate your help.
    • A little progress; I took the opportunity of an oil change to take a sample for oil analysis, will be interesting to see how it was treated for its first 125,000klm (I know how it has been treated since :rofl:) I went with 5w40 and will see what that does for oil pressure at higher revs. Also fitted the Z1 front undertray....a little more sturdy than the plastic factory one (although I suspect it won't stop a tree stump ) Nicest thing about it really is the 2 bolt "service panel"....a gift to the oil changer compared to removing 14 bolts holding the factory tray.
    • I think a scissor lift is better/faster in most cases, but I guess it does obstruct access to the centre of the car? BTW I weighed the quick jack. 3.5 tonne model is 50kg for each side. So yes, portable, but not with one finger
