KK's-R33 Posted July 20, 2007 Share Posted July 20, 2007 I just painted my car and put interior back in and also had to put in a deck. Basically what happened know is the dash lights and parkers dont work. I triend checking the fuses but cant read japanese. Can any one help is there a translation for the fuse labels or can this be cause from something else. Any help would be great. Cheers Link to comment https://www.sau.com.au/forums/topic/177433-electrical-problem/ Share on other sites More sharing options...
ROB32T Posted July 20, 2007 Share Posted July 20, 2007 http://www.skylinesaustralia.com/forums/in...nglish+fuse+box pretty sure there is a link in the third post down dude Link to comment https://www.sau.com.au/forums/topic/177433-electrical-problem/#findComment-3240911 Share on other sites More sharing options...
Mid_Nite_R33 Posted July 20, 2007 Share Posted July 20, 2007 did you check the fuse box under the hood? check the 5 little fuses, one of them causes no dash lights from my experience Link to comment https://www.sau.com.au/forums/topic/177433-electrical-problem/#findComment-3240934 Share on other sites More sharing options...
Godzilla32 Posted July 20, 2007 Share Posted July 20, 2007 I had this same issue in a 32 it turned out i used the stereo dimmer wire as a ground and it shorted out the fuse. Its all on the same fuse. Check that out. Link to comment https://www.sau.com.au/forums/topic/177433-electrical-problem/#findComment-3241056 Share on other sites More sharing options...
KK's-R33 Posted July 20, 2007 Author Share Posted July 20, 2007 Thanks guys. I opened the bonnet and checked the fuse box there but there wasnt any fuses there just relays. Link to comment https://www.sau.com.au/forums/topic/177433-electrical-problem/#findComment-3241060 Share on other sites More sharing options...
Mid_Nite_R33 Posted July 21, 2007 Share Posted July 21, 2007 Thanks guys. I opened the bonnet and checked the fuse box there but there wasnt any fuses there just relays. hey, there must be fuses under the hood, aboout 4-5 of the same slide in type as the fusebox inside the car, right near the big relays. mayb you just dont have any there, if not put some in Link to comment https://www.sau.com.au/forums/topic/177433-electrical-problem/#findComment-3241942 Share on other sites More sharing options...
EKSMUD Posted July 22, 2007 Share Posted July 22, 2007 there's fuse box in the boot check it out. i had this same issue like 2 moths ago.. Link to comment https://www.sau.com.au/forums/topic/177433-electrical-problem/#findComment-3243605 Share on other sites More sharing options...
