10 minutes ago, GTSBoy said:
That's not a parking light globe. That is a main headlight globe.
You've touched it (the quartz envelope) with your fingers and now it's f**ked, so you have to buy replacement for that too.
na its the fog lights/parking lights and it was dead thats why i thought to replace it
ive checked all the lights and its all working except that one bulb
45 minutes ago, GTSBoy said:
That is an H1 headlight globe. Not a parker. 55W, quartz halogen.
Outer are the headlights yea and the parking/fog lights are the ones inside? still working even though I left the bulb out
IMG_0563.jpg?ex=6683adf5&is=66825c75&hm=116a6a2e7715fc893835e1661a517c83dd6d9faa82d3de69aead8b9a1b2c3531&
Edited by YouTRIPPIN?
actually they are fog lights, parking lights are somewhere else that i cant get to from the engine bay because its too tight 😥
On 7/21/2007 at 12:04 AM, T88turbo said:
I bought some white LED lights for the front parkers as the stock one come out yellow.
Cant get access to the damn thing to remove the bulb.
Any suggestions?
I am not certain on the point, but these lights look like your running lights, which are specifically coloured towards the yellow spectrum, as it is more easily seen in fog. And as such may even be required by law to be coloured like that.
    • Nope, but they are definitely one of the default choices. Well established.
    • Has anyone used > https://performancecoating.com.au/
    • Haha actually I did join back then under a different email address,  I couldn't re-activate my account so made a new one! I didn't post much anyway so not missing out on much. Amazing to see how the value of the cars and parts has changed over the years, also ACT section appears to be dead now.
    • Thanks... It's in pretty good condition overall, probably due to not being drifted/tuned however being a daily driver has taken its toll. Had 100k on the clock when I got it, up to 180k now. Unfortunately it's not 100% dent free, it's got a small dent on FLH side and broken indicator from where I hit a small kangaroo at high speed. If you look at closely at pic #5 you might spot the dodgy trailer light repair my old man and I rigged up as temporary repair! - It's still there due to a combo of needing the car as daily driver and then too lazy/busy to fix properly. I've a couple of other minor accidents accidents as well but nothing major. One required a new front bar and unfortunately the smash repairer ordered the normal gtst one and not the aero bar. Needed the car back asap so just went with it, regretted ever since.
    • I can't believe that anyone is foolish enough to believe that the base maps are for any other purpose than to drive the car up onto the trailer/truck or gently creep it to the dyno. No matter how good they are, they can never be any better than the factory maps**, and only the foolish trust those on a significantly modified setup. **Yeah, yeah. I know there's also the difference between factory maps being fixed to certain injector sizes and MAP/AFM/VE relationships, and the likely aftermarket ECU base maps being better able to handle the sorts of changes that would render a stock ECU dangerous, like different sized injectors. But let's just ignore that for the moment, because the principle is still the same.
