  • Replies 843
Posted Images
The block hasn't been cryo'd but it is mostly grout filled. Cams go in today and then the external pickup will be mounted and welded in place. Then the bottom pulley will be adapted to the balancer and then it's in the ute and off to Bezerkley to fit and mount the oil pump so we can order the right length belt.
grout filled, is that a must do once you reach a certain power level with a rb engine?
Certainly not a 'must do' - more a case of 'why not?'
your diff looks wierd mate. where is the tube for the front drive shaft?
I don't see a diff in that shot?!?!
So with the Plazmaman intake on one side and the coated shit on the other, I thought I'd spend some time polishing the cam covers. I wasn't aware just what 'some time' really meant. Holy crap this takes a long time.
At this point I've cleaned them up with 240 and gone over this one again with 400. Then comes 600 and then polishing. Time consuming plus!!! I should have started this process a long time ago. One of the two covers has a pressed indent in the top that looks like it was meant to have a badge in it at some point. I ground that out together with the casting marks around the base as well.
