yeh, those mount definately will not work, they are different heights. look like R32 GTR mounts. yours are the same as z32 300zx, same family, whales and boats. ha ha. We will get some new standard ones ordered 2moro, and get this external oil pump bracket sorted, then you can continue to bolt all your toys on.
You should know whether they will work by looking at them. You were the last one to see them alive, Stu. :D
  • Replies 843
Posted Images
Spent a day in the workshop at Bezerkly today finishing up the oil pump mounting bracket (which had to be modified to accommodate the power steering bracket and pump) and fitting up the intake and exhaust side of the motor. I've posted some pics so you can see what we started with and how it ended up.
This is what we started with this morning. The bracket had been made for the oil pump but it used the power steering pump holes instead of those once taken up by the air con pump.
This photo shows the new location for the bracket and the holes (above) that it once occupied.
The view from the front of the motor.
This is the modified bracket with the new 'L' section connecting it to the block at the top of the bracket.
This shows the pump mounted to the new bracket and the belt running to it.
The long motor with the pump mounted to the newly modified bracket.
Then things got a little more interesting. We started unpacking boxes of goodies that the car fairy had deposited at Bezerkly earlier on in the week. These goodies included the intake and exhaust sides of the motor.
Tomorrow morning the car is leaving my shed and heading into the workshop on a tilt-tray to emerge soon as a running concern.
Starting to get really exciting now!
you look to have explained it very well, besides everyone can see how good my work is. besides this thread is more interesting than mine at the moment. lots of bling to be seen. at least you know you can always enter the car in autosalon if it is to slow. ha ha ricer...
Shouldn't you be posting in here?
Edited by BezerkR32
You shouldn't post after more than one beer. New rule. :thumbsup:
soon is the emphasized word, unfortunately adrian is learning the hard way as we all do that when you modify, you can expect teathing problems. When you modify to the extent that adrian has, the more problems to rectify. some due to poor workmanship of parts supplied, others down to poor or miss-communication, and somethings you just cant forsee, oh the joys.
After repositioning the external oil pump bracket, which was much less painless than expected, we continued the fit-up. next was the plenum. Looks pretty enough but was quite envolved in fitting. It was found that the studs supplied bottomed out before they were flush with the base, which meant the gasket had no crush and would not seal. had to remove all studs, countersink holes in plenum, clean threads then re-install studs.
Plenum was now fitted. all was good until it was found that the vacuum port thread for the brake booster was welded over. had to mask plenum up, die-grind weld back, re-tap thread and machine fitting down.
Just when we thought it was all good we found that the throttle cable bracket did not have enough clearance for the cable retaining bolts. So out came the die grinder again. This was a mission for us in a workshop with all the tools necessary. Hate to have been attempting this at home in the garage.
Next was the turbo water feed plumbing. The factory pickup point was unfortunately overlooked when the block was grouted so had to find an alternative point. ended up using the port behind the thermostat housing and eliminating the bleeder port and throttle body plumbing.
next was the oil pump/sump plumbing. Just before fitting the engine it was noticed that the position of the sump pickup fitting was in a position where it would not clear the engine crossmember. Could have been worse i guess, could have fitted the engine and then noticed. The sump will have to come back off and the fitting moved.
Hopefully after all these issues are rectified it will be smooth sailing for Adrian and his project. But lessons have been learned all round. sometimes too many cooks spoil the broth, but it will all be well worth it in the end. The worst part is these setbacks which require rectifying are time consuming and therefore expensive to resolve. An unwelcome additional cost seeing you have already payed good money for the item or service provided. This is not even a case of you get what you pay for as sometimes you pay good money and it still the product or service falls short due to poor communication or workmanship.
At the end of the day communication is the key, when you are getting something fabricated or supplied, get some advise from whoever is fitting it as they may have encounted issues with products previously and can help to avoid these issues. but on some occasions you just have to suck it and see.
After the sump is modified the engine will be fitted and it should be smooth sailing.
Adrian would have much loved to race his new baby this weekend but as you can see its not going to happen. He will be racing however in a borrowed car, wish him luck for the meeting and his project.
cars getting close to running soon now then :)
Good luck with her - be great to see how you get on :D
Everytime i enter the part number into a website that sells these mounts,it keeps coming up as RB25DET NO HICAS.They must be able to fit both 2rismo's and my car?
If more people knew the grief involved before they started there would by way less modified cars out there. Its been almost 12 months of modifing the modifications, hacking, cutting changing, discarding, reaarranging components to get it all to work as a unit. I thought I did my homework but there are so many hidden perils just waiting to bite you on the arse.
The next person that tries to sell me a part and insists it simply "bolts straight on" will have said part rammed up their coit.
THERE IS NO SUCH THING AS A BOLT ON MOD?
Good luck with this build 2rismo and i hope your pain is way less than mine has been. There are quite a few up here keen to see your car run at jambo.
seriously, yor quite welcome to come to the shop and have a go, but they are the same mount that came out of my 32gtst, 33 mounts are round. they will not fit without modification and even then, what makes them any better than the standard mount that lasted 12 years before failing.
good post stuart - people incorrectly expect these things to just bolt up and off you go. as you said it is hard enough in a workshop let alone the garage at home.
one poorly made set of gtr dumps we had were on and off 4 times for modification - before we finally found out that they were not going to clear the gearbox bellhousing. bad words were said that day.
Too bad about the Plazmaman plenum Stuart, I made a thicker gasket for my plenum (I think it mentioned that in the instructions that came with it?)
Looks like the build is going on very nicely though.
Keep up the good work and look fwd to see how it goes on the black stuff. :D
    • Foreign debris, physical shock, boost leak, could be anything honestly. The danger in taking all the timing out of a tune/hitting the R&R corner is that even if the engine doesn't detonate your turbo is taking a lot of abuse from high EGT. Also, even if nothing goes wrong it is a journal bearing that is spinning at 100k RPM on boost. Eventually it goes through enough cold start/pressure cycles to wear it out.
    • I kinda accidentally saw this, and was interested, but It actually seems to replaces the whole center computer, using the existing screen and buttons. AND it may only be for a G37 and not compatible with a Japanese 370. So its not for me, but someone else may be interested to look into it. Its about $680USD. If I am understanding it right, it basically replaces/installs and android pc that integrates with the existing screen. But I could be wrong. https://gromaudio.com/vline/ The video I first saw was the following, with very little and unclear details.     Even if your not interested in the system, the video on their site was pretty comforting in showing how simple the whole centre comes out
    • hfygrte52 what side you looking for? Do you care what color car it's off? Found a white LH side on here: https://skylinespares.com.au/product/nissan-skyline-r33-coupe-rear-tail-light/   Aussie parts place but will ship to USA. Maybe get it before there's a tarrif on 25yo shit box parts
    • I’m with Shannon’s for all 5 of our cars. Agreed values seem fair, premium price is okay. ($210 ish a month, all comprehensive).  Have claimed once with them for a not at fault claim with another car where my car had no damage. Was one call after the incident and an email after. Deemed not at fault so premium didn’t go up either.    I have called up and spoken with people who are not familiar with certain cars and didn’t agree with me on value or let their personal vehicle preferences effect the call. But called back later and got someone else who was more agreeable.
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
