in that case i hope it does otherwise your going to be up for some exhaust manifold mods, as your compressor housing is tight now. wont get anything bigger on.
Going to run the GT35 hard and then swap for something bigger. Either a 42 or a 51R. That is provided it the 35R won't do what I want. If it does, then there will be no need to change it.
  • Replies 843
Posted Images
the driveability of the 30/40 is excellent, have fitted this turbo to half a dozen r33s, two auto, the majority of these with standard internalls. adrians with the bigger exhaust housing due to the engine mods and use of gas. you be silly to upgrade to anything smaller. I would seriously consider gt42 if it is a auto race car.
all-so finished the pressure side of the oil system, ran hose around radiator and through inline filter on driver-side chassis rail. there is a good 2 meters of -12 hose which eliminates the need for an oil cooler. mounted filter in a bosch fuel pump bracket.
my work is almost done.
is that length of hose going to effect the oil pressure at all?
No and the pump itself has some scope for pressure adjustment even if it did. The pump is considerably more robust and powerful than the stocker.
Man my turbo is going to look tiny as a highmount compared to that.Maybe a GT3082 is on the cards :laugh:
Have you mounted it yet?? You should find it doesn't look tiny, we've had a GT3076R and a GT3582R next to each other - the GT3076R does not look a hell of a lot smaller at all.
2Rismo - considering GT42RS?? Why did you bother going a GT3582R if you had the idea you might go something that big down the track :(
2Rismo - considering GT42RS?? Why did you bother going a GT3582R if you had the idea you might go something that big down the track :)
The 35R is a legacy of the last incarnation of the car/engine. I plan on pushing it pretty hard and I think the results will surprise. I'm a long way away from a turbo upgrade.
Haha I know the GT3582Rs are underestimated by many, would love to see one pushed to the limit on an RB25. So long as you go 1.06a/r turbine housing you will possibly blow people away, I've known people to run near 150mph on them.
wtf, if you are only a possibillity of beating people running 150mph, then i think we should pack it up know.
    • Foreign debris, physical shock, boost leak, could be anything honestly. The danger in taking all the timing out of a tune/hitting the R&R corner is that even if the engine doesn't detonate your turbo is taking a lot of abuse from high EGT. Also, even if nothing goes wrong it is a journal bearing that is spinning at 100k RPM on boost. Eventually it goes through enough cold start/pressure cycles to wear it out.
    • I kinda accidentally saw this, and was interested, but It actually seems to replaces the whole center computer, using the existing screen and buttons. AND it may only be for a G37 and not compatible with a Japanese 370. So its not for me, but someone else may be interested to look into it. Its about $680USD. If I am understanding it right, it basically replaces/installs and android pc that integrates with the existing screen. But I could be wrong. https://gromaudio.com/vline/ The video I first saw was the following, with very little and unclear details.     Even if your not interested in the system, the video on their site was pretty comforting in showing how simple the whole centre comes out
    • hfygrte52 what side you looking for? Do you care what color car it's off? Found a white LH side on here: https://skylinespares.com.au/product/nissan-skyline-r33-coupe-rear-tail-light/   Aussie parts place but will ship to USA. Maybe get it before there's a tarrif on 25yo shit box parts
    • I’m with Shannon’s for all 5 of our cars. Agreed values seem fair, premium price is okay. ($210 ish a month, all comprehensive).  Have claimed once with them for a not at fault claim with another car where my car had no damage. Was one call after the incident and an email after. Deemed not at fault so premium didn’t go up either.    I have called up and spoken with people who are not familiar with certain cars and didn’t agree with me on value or let their personal vehicle preferences effect the call. But called back later and got someone else who was more agreeable.
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
