Can anyone recommend suspension modifications for an R33 GTS25T for track days, ie., Supersprints? Better still can anyone recommend a Skyline specialist to do the work? I live near Nowra but I guess I would have to go to Sydney to get same.
I have fitted 17x8's with 235x45x17 street legal competition tyres but the car has stock springs, shocks and ride height.
https://www.sau.com.au/forums/topic/17749-r33-suspension-mods/
Hi Paul SM,
Whiteline have a suspension kit, details on the web site. 2Rismos car was the development car so you might want to pm him to see what he thinks about it. The kit should be able to be sent to pretty much any suspension shop since the developments already been done.
  • 5 weeks later...
I have the Whiteline kit im my R32 GTSt, and very happy with it. If you are looking for a road car setup that will look after you on the track then it is a good compromise.
That said i drove an R33 with Nismo castor rods and susension arms, with HKS coil overs... and oh my god. On normal road rubber i was matching, on some corners quicker then the corner speeds in my car with semi slick tyres. But rides pretty hard on the road.
Either way speaking to whiteline would be a good place to start, i understand they are a distributer for Drummond coil overs as well if you want to get really serious. They should be able to find a setup to suit you.
Thanks Roy,
I have already been pointed in the Whiteline direction by two other members and have acted immediately. I had the full kit - springs, shocks, bushes with caster camber adjustment and adjustable bars installed by Selby South Coast.
July 20 and 21 at Winton will be the acid test.
Paul SM
P.S. you're right about the ride - it's very firm but I guess I'll get used to it.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
