HICAS only kicks in when the car is travelling over 80km/h, rear wheels turn 1 full degree and you can feel the car 'kick' alittle. Thats only if you are turing a large bend around a highway or blasting it through a corner.
If you check the powersteering fluids front and back, check the fuse as I have mentioned in other threads
https://www.sau.com.au/forums/topic/177506-hicas/page/2/#findComment-3644272
its that going effect my car lyk handling?wot u reccomend to fix it?
you should be right, i dont think the hicas will activate if its in error mode. being a 33 its all electric so nothing to do with fluids. you could check the fuses, easiest thing to do.
if they are all ok and you still have the stock steering wheel put it back on and see if you still have the problem. if it goes away then i'd look for a boss kit that is hicas compatible, i remember a thred out there where everyone was listing the boss kits they used and that were compatible.
https://www.sau.com.au/forums/topic/177506-hicas/page/2/#findComment-3644285
Lockbar. For (as stated earlier) between $30 and $300 you can have a lockbar. Your HICAS light will stay on, but no more weird arse feeling in the back end :)
HICAS operates at speeds heaps lower than 80kph..... Fang it around a roundabout and you will feel it... The angle of (rear)steer depends on what speed you are doing at the time... Ie. If you are dawdling around a carpark, you will NEVER feel HICAS operating.... It will however operate above 30-40kph. At lower speeds the rear wheels turn in to aid steering and at higher speeds they travel in the same direction as the front wheels(depending on how much lock is wound onto the front wheels).
When drifting with HICAS you can really feel the rear wheels trying to straighten you out of the slide. It also gives you a really false sense of where the car is actually pointing...
On my mates skyline when hicas come on the sterring gose all stif. What dose that mean? :banana:
Low fluid if it is pre Super HICAS
https://www.sau.com.au/forums/topic/177506-hicas/page/2/#findComment-3669191
    • See my post here If you put the Haltech in, you won't have to worry about any of that. And, in case you're worrying about my lack of credentials in doing your exact swap, I put a Neo in an R32. There has never been a stock boost solenoid near my car and the Neo's ECU has never cared. Nor should it, because it is electronically impossible for it to care.
    • That's 100% wrong. Did you wire in the boost sensor? If you did not, then that is 101% your answer. Neo ECUs do suck a bit.
    • Hello, I'm trying to make this thread basically the thread with all the answers to common questions regarding specifically the RB20 DE NEO + T engine, that comes in the R34. Answers will and only should be provided by those who have done this conversion or actually have some relevant real life experience please. Please feel free to ask questions in the comments if you have any so other members can answer. I feel like this thread is really needed, especially with more Americans buying (unknowingly going to regret it too) rb20 neo r34s. My first question being - What do you guys use for tuning? I have purchased a haltech elite 2500 Plug and play kit for the rb25det NEO because the ecu plug is the same, but I am unsure if any of the pins would need to be repined to match. Second question that I see asked very often - After this conversion, did you install the boost solenoid/ actuator? I see many people doing a + T setup on their rb20 NEOs while running stock RB25DET NEO ECUs with no tune. I am wondering how they are going about doing that and consistently abusing the car because many of these people have had these untuned setups running for a very long time. That was my original plan, but my engine cuts out at 5 psi of boost using the stock ecu with no tune and no boost solenoid/actuator.
    • interesting. ive read and heard otherwise over the past year. ive been doing this +t conversion on a rb20 neo using all oem rb25det neo parts including the ECU, and im having engine cut out issues when I hit around 5 psi of boost. Everywhere/everyone ive asked has told me its because I never wired in a boost solenoid/actuator to the ecu, so the ecu isn't getting the right signal once it hits 5 psi of boost, causing the engine to get shut off.
