hey guys
as some of you know, i bought a front bar off ebay and posted it up to say how good it was.
http://www.skylinesaustralia.com/forums/in...howtopic=173731
well i got some more bragging to do as today i got it back from my panel beater who during the week sprayed it up for me and i brought it home to fit. looks awesome!!
some may remember from my previous post, that the bar had a small amount of gap between the headlight and bar. something common i was told in after market bars. i was gonna use a packer to remove the gap, but after some deliberation i tried a different approach. i ended up turning the 2 round holes in the reo (ones that hold it to chassis) into oval holes and opened the forked gap at the back of the mount up. this allowed me to pitch the reo up higher than standard and thus close the gap so much that a packer was not needed. just bolt her up and drive away. check it out.
please ignore the hair dryer in the photos, i was using some sealant from work to bond bolts onto the back of the gtr grille copy so i could mount it. also the icy pole sticks are there to provide support to the grill and hold in position while the hair dryer was drying.
like ive said before, if any1 ever gets an after market bar and needs a hand to fit it up before they spray it, pm me and im more than glad to give u a hand. (melb only, lol)
hope you guys think it looks good.
Edited by cheez
https://www.sau.com.au/forums/topic/177516-great-ebay-body-kits-2/
Don't suppose you have a pic of this process fitted up?
I'm fairly sure I know what your talking about and I'd love to give it a try on mine as I also have a problem with the holes in the bar lining up to the ones on the guards.
wow man that looks great so tempting to buy one just interested how much it cost u for a guy to spray it? and who did it for you?
spraying it up cost me $300. that was with a primer and block back to get rid of any possible pin holes, and then the colour. the guys @ GP Smash repairs in Epping, vic did the job. they @ 53 miller st.
yeh i do. here it is. this is the side on view on the reo. the front 1 (left hole) is the 1 that i elongated and made oval. the back 1 i just grinded to allow for the extra pitch movement.
there is a b4 and after of the gap.
good stuff bro - glad it turned out good for you in the end.
Hih ihi hi lol - the hair dryer - yeah, we all know what the V8 boyz think about us turbos... lolz
looks like it fits on wheel... good stuff...
my indicators were out of my gtr style front bar that came with the car when i bought it. not sure where u can get them from but im told that you can use trailer indicators which are the same size only that they are orange rather than clear.
Hey cheez you got any pics of the car with the bar fully fitted and bonnet closed etc? like out on the street. I'd love to see how the car looks as a whole with the bar on it. :laugh:
this is it on the car. hadnt fitted up the number plate yet, but will be getting slim line plates and putting them on.
    • And the full R32 GTR wiring diagrams are also freely available. Hmm.... there's supposed to be an auto replace that would have linked the thread. Here it is, manually
    • Ahh...should have been clearer ~ there's 2 ... SMJ = super multi junction (connector)...   ...this is connector 6 & 25 in above image -- body harness to engine loom (6) & body harness to main loom (25) Headlights go to front via connector 6 ; fuel gauge goes to tank sender via connector 25  ...like I say this is R33 diagrams, but at a pinch R34 won't be too far different. *IF* the two ground faults are related, this can be the only place where both wires converge (as one runs to the back, the other to the front)... ....thing is, you probably need to establish if the faults are related (unless you examine that area and find obvious chaffing on the looms there to body ground)....*IF* the fuel gauge is still broken (full needle deflection), I'd be headed for the boot, remove fuel sender wire, key on and measure the voltage there ~ it should be roughly 10volts. If that's ok, check sender to ground resistance...if this is a dead short to ground (and there's fuel in it), then sender has failed or something funky has happened to wiring in the tank. edit: ahh...rereading the thread, this is R32....above fuel sender test still valid tho'
    • I just changed the timing belt on my RB25DET NEO and wanted to get some opinions. I’ve been super cautious, did a lot of research, and took my time. I’ve driven the car, and it runs fine. After warming it up, I revved it to 8000 RPM a few times—no issues, everything held up.   After the drive, I heard a noise that I think is either the clutch or possibly a tight accessory belt. It’s not constant, just comes and goes.   I took the timing cover off to double-check everything:   Belt is on properly, Tensioner is tight, Did the 90-degree twist test—belt isn’t too tight or too loose.     What still worries me is that I noticed the belt seems to sit a little toward the front edge of the gears, especially on the idler pulley. It even looks like it’s slightly coming off the edge there. Is that normal?   My old belt (5 years old, ~3,000 miles) also showed a bit of wear on that same edge, so maybe it’s just how it sits? I’m probably overthinking this, but since it’s my first time doing this on a NEO and the engine is forged, I really don’t want to mess anything up.   Also, I’m thinking of swapping to a clear front timing cover with the glass window. Would you recommend NITO or HPI? HPI looks reputable and their covers have 2.5mm thickness, but not sure if there’s a real difference between the two.   Any advice or reassurance would be much appreciated!
    • 40 grit sounds about right, to start. You make some decent cuts/damage in the coating with that, then rapdily scale up to maybe 80 and 120 for the bulk of the actual removal, then fine it off to 180 or 240 perhaps. No need to go any finer than that, and maybe no need to go even as fine as that. Wrap it on a big block and have at it. At least on the hub face.
    • Do the GKTech rear lower control arm mount relocation, and either alloy subframe inserts or very stiff subframe bushes. Traction is going to be at a premium!
