Got this from a local forum that I visit, some guy brought a piece of land in Portugal, found a mysterious barn and broke into it. This is what he finds!
Link to Pics: http://www.intuh.net/barnfinds/afa70.htm
Story: http://www.sportscarmarket.com/articles/archives/1110
Thought some of you guys might find it interesting, it would be great to find this in one of my sheds... :D
https://www.sau.com.au/forums/topic/177527-barn-full-of-cars/
barn my arse! thats a warehouse!
how could you buy a block of land then look to your right/left and go,...oh yeah look at that barn lets have a look whats in it seeing as i never noticed it before. it looks like its the size of a soccer oval.
trippy story, nice find
Have seen this link on many other car sites. Reposted to death. Maybe about a year old! Interesting when it first came out!
a crazy italian business man bought a fezza and bricked it up in an office or something alike...
he died, everyone forgot, and they found it when they demolished the building... zero kays.
some story i heard, don't know if there is any truth
fark. get a good cut and polish on the lot of them sell every single one and buy some real cars. lamborghini murcielago 640 or the new diablo gt roadster limited edition sounds real tasty.
there all shit boxes any way. i dont like old cars at all.
google earth/pro
do you need to pay for it or can you "get around it"
do you need a really good graphics card because i have downloaded the 50MB file thing before but it doesnt seem to work
sorry for changing thread topic i probly should have just sent this to the dude in pm, oh well too late now!
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
