Talk to Bullet 22 about Federal Tyres - my Federal 595rs's were so sticky at Wakefield that we had the little GTS-T up on two wheels on the last corner, and they're street legal. They might have something a bit harder that will last longer than the 595rs's and may be a bit cheaper too.
My lap times have improved significantly since getting the Federals, so I only have good things to say about them.
https://www.sau.com.au/forums/topic/177530-tyres/#findComment-3242110
there is a place in fyshwick that does second hand tyres for ok prices i forget what they are called though... in saying that if bullet32 can help you out with some federals you should be happy. If you want a tyre other then federals give Marc out at Discount Tyre Service Belco a call he has hooked me up with to many tyres to list at great prices. Also a top bloke and always up for a chat.
https://www.sau.com.au/forums/topic/177530-tyres/#findComment-3242121
You're thinking of Northwest Tyres. They're ok, but I bought a set of tyres there and scrubbed them out in 10,000km. You get what you pay for though.
Secondly, Marc left Canberra 2 weeks ago for sunny Hervey Bay in Qld, and no longer works at Goodyear Autocare (Previously Discount Tyre Service) in Belconnen. I would still recommend them for a good set of tyres as the guys that work there really know their stuff about tyres.
https://www.sau.com.au/forums/topic/177530-tyres/#findComment-3242132
wtf is this just a holiday and does he still work at the Gungahlin one ??? lame...
https://www.sau.com.au/forums/topic/177530-tyres/#findComment-3242380
My understanding is that he still has an interest in the the two (Gungahlin and Belconnen) but has started another one down at Jervis Bay.
Yep thats the message I received as well. Marc will be back and forth a bit but spending most of his time down the Bay (the other bay).
https://www.sau.com.au/forums/topic/177530-tyres/#findComment-3242462
Hi Guys - yes you are right and yes you are wrong. I have sold the Gungahlin store but still own the Belconnen store. All Discount Tyre Service stores have been re-badged Goodyear Autocare stores.
Also, I have moved to Hervey Bay and purchased another business - brake, clutch and steering.
If you are looking for tyres in Canberra pm me as I can still organise the right price for you at Belconnen.
In my absence - enjoy the cold 'cause I can guarrantee you that I am enjoying the warmer weather.
https://www.sau.com.au/forums/topic/177530-tyres/#findComment-3242851
Hi guys,
quick note to say that i got Marc to help me out at the belco store.
Big thanks to Marc and the guys at the store who were very helpful!!!!!
Wow...never knew that an r33 actually handled :P
What did you get?
Federal's I hope? :)
https://www.sau.com.au/forums/topic/177530-tyres/#findComment-3251287
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
    • The only high-power RB I've personally seen go pop after running for all of an hour on a dyno was built by B2R, while being remotely tuned by B2R. The only wastegates I've ever had leak like a sieve, return, still leak, return and get shipped back the wrong ones were from Turbosmart. The only final drive that I've ever purchased that were unusable, twice... were from Speedtek. The only seat mounts that I've ever purchased that placed the seats in the door frame were from Crank Motorsport. The only poorly designed parts that I had the manufacturer confirm should have been designed as per what I mentioned were from GKTech. The only ECU I've had firmware updates consistently break things are Haltech. The only catch can I've purchased that didn't fit in its advertised spot was from ATP. So forth and so on... Moral of the story, doesn't matter where it's from. Do your research beforehand and stick with products and companies you've trusted in the past.    @joshuaho96 If you want it done right, do it yourself.
    • Something coarse-ish. 180 is good.
    • I was surprised to see all the quick Jack models at the same prices on there. But yeah, grabbing one at 20% off would be great.
