At the moment im looking to buy some rods for my RB25.
My power goal with my next turbo is around 280rwkw.
Just wondering if GTR rods out of a 34 would fit my engine?
I would be getting them shot peened and balanced.
After that would the rods be able to take the punishment or am i better off getting Eagle rods?
I just think the forged ones might be over kill.
Oh does that mean i have to get GTR spec pistons too?
CHEERS
https://www.sau.com.au/forums/topic/177545-gtr-rods-for-my-rb25/
The Eagle ones are $810.
I can get the GTR rods for $200
Tomei rod bolts for $150
And shot peening and balancing would be around the $200 mark????
Or you could just use GTR rods, no need for balancing(as long as you get a set), rod bolts or shotpeening for 280rwkw
(and you use rb25 pistons)
Edited by Adriano
im using r33 gtr rods in my rb25, balancing is a MUST. such an important part of an engine build why skip it>? 1 of my rods was twisted and they were out of wieght from eachother by upto 5grams each, dont skip the balancing part, i didnt get mine shotpeened or nitrided but did get new arp rods bolts pressed in.. at the end of the day probably is best to go with after market rods depending on your goal with the car but if your anything like me you end up wanting more power so really decide wat u want car for n spend accordingly
for ~280rwkw is it really necessary?
if engine is apart then i think do asmuch as u can afford.. saves alot of headache later.... stock rods might handle 280kw but wat if the need for more power is felt and then this forged motor with stock rods are now hampering the potential?? seems like alot of wasted money pulling engine apart to fit rods when could have been done when engine was apart first time...:) my thoughts anyway
I hear there isnt much difference between RB25 and RB26 rods anyways... Shot peen ur 25 rods, balance the crank that shold be that part sorted. Forged pistons for an RB25 and it should be fine. If ppl can be making 230-240rwkw on stock internals (new here so dont if the figures r higher) then a bit of strengthening and balancing wont hurt.
Liam
26 rods are good for well into the upper 300rwkw range, some even into the 400rwkw.
An upgrade if you have the motor apar IMO when you can get a set for $150.
That way if you chase a bit more power later, your already setup for it
    • Solid update, got all the downforces now.  You going to be running aus time attack again? love the jacking solution, spend the dollars on what makes it go fast is best way.
    • Back in January, I noticed my car felt noticeably weak. I had the injectors cleaned, which seemed to solve the problem -- until now. Recently, the car suddenly lost power again while driving. Suspecting the injectors, I brought it to the mechanic. He recommended replacing them entirely, saying the current ones were getting unreliable and fiddly to work with. I could not find a direct replacement for my current injectors. The closest match I found were 440cc injectors. This led me to look into the possibility of upgrading -- and of course, that would mean remapping the ECU. From my research I found: The OEM Part numbers are 16600-72L20 and 16600-72L21 Both the RB20DE and RB20DET use the same 270cc injectors. There are much better options out there over the old OEM injectors. Nistune could be a viable tuning option. While the RB20DE isn’t explicitly listed on their site, the ECU is essentially the same as the GTS-T version - just with a different map. The ECU code on mine is listed as supported. One concern is finding a tuner who works with Nistune. Aftermarket ECU like Haltech and Link, but this would be the most expensive choice (and possibly overkill for a mostly stock RB20DE) I admit that I am very new to the tuning scene and would appreciate any insight or recommendations regarding this.   These are some SAU links where I got some of my information from for reference: https://www.sau.com.au/forums/topic/380324-rb20de-injectors/ https://www.sau.com.au/forums/topic/477396-factory-270cc-injectors/
    • The inspectors are not forensic by any means but if you forge your documents and/or badgings on vehicle parts and are found out, the consequences are just far bigger than if you just run illegal parts. And their job quite literally is to cross reference what parts you got installed and what your papers say you got. Something as silly as your suspension being 1mm too low will fail you. Nonetheless I asked if someone knew the damn pipe and I certainly did not ask for smartassery or underhanded comments, no idea why you need to be told this. Great way to waste both our time.
    • As useful as you explaining what forgery is... But then again, I wasn't aware your inspectors were also forensic experts and inspect nameplates on each component to confirm everything is original. They must inspect roughly 3 cars a year at that rate. You're right though, my comment doesn't help you in anyway, so I'll go talk to my wall now. Cheers.
    • Say that to the guy that is going to fail your inspection or tow your car for illegal exhaust modifications. If you have anything else useful to say, please go tell your wall.
