Vn Coilpacks On Silvertop Rb20det
Quigga
 Share
Seen it done plenty of times, usually with bosch GT40's (essentially the same thing)
wiring is extreemly basic, just extend and add the right plug
not too sure how the ignitor would hold up.....can't see there being a problem though
There are a couple of threads on here on how to do it with different coilpacks. Unfortunately the igniters dont handle it so well, as these coils have a much higher current draw, and th other problem is the ignition dwell time isnt suited to the se big coils, so they dont fully charge(saturate), hence you dont really get the full benefit of the big coil. I dont think ive ever heard of a splitfire dying, all the people that ive heard of having problems with them are because they fit splitfires to fix something which wasnt the coils.
can u upgrade the ignitor pack to handle the coil packs? is there anything out there that is suitable
lol thats my question :ninja:
ive seen splitfire coilpacks to suit my GTR for $350. if the cheapest you have seen is for $600, then id suggest you look a bit more. easier then modding the wiring looms and changing the igniter. My 2c anyway
Over here (in Malaysia) we use Mitsubishi 6A12 (2.0 V6) coilpacks due to the lack of reliability of stock RB coils. But we use Megasquirt instead of stock ecu or Power FC... So far only 1 or 2 cars used this setup (experimental stage) and so far there's no problem...
how about hyundai sonata coilpacks. the 3 packs of 2 coils if you know what i mean. like the commodore ones but for a hyundai
thanks for ideas but to keep to a tried and true type msg, also running fairly stock so adjusting recharge wont really be a major issue, so ill just use rb ignighter and VL coils, ill do a lil writeup after as well to help ppl in my situation later on
hey man,
parts needed:
VN Coilpack(the square type one, or the round, i've got the squarer one, because it looks better against my firewall)
VL set of sparkleads, shouldn't be too much or mix and match your own :fakenopic: just get the NGK or Eagle ones from supercheap
use a VN coilpack(Block of three coils with 2 spark leads on each side)
they are round $60-80 new i think? try the local holden dealer
sell your old coils for whatever yuo get for them, usually $20 each or so(here in NZ anyway, not much because they are poo)
keep the coil loom, cut the wires at the end, label them all though :) for each cylinder, then wire them up, i think it goes 1/6(first coil 2/5(second coil) 3/6(third coil)
It'll make it dead easy to change sparkies as well :rant:
I think if you want to use the original VL coilpack, you'd need some way of firing it? because it's dizzy standard isn't it? not sure if an ignitor would work in that sense, although it could do
Ah thankyou thankyou thats exactly wat i was looking for, VN ones not VL would be the go
the ignitor isnt really an issue yet
Like before ill do a writeup with photos when i do it
if the ignitor cant handle the current draw, what about relays? 6x GT40's with relays direct to the battery, would be ideal wouldnt it?
and on that note, what about adding capacitors etc?
Edited by SKiT_R31
this is a reply to the first post. vn coil pack fire both sparks together. on a vn it will be matched to one cylender that is on its power stroke and one cylender that is on its exhaust stroke to burn any unburnt fuel. it all helps with emissions. so you need to make sure yours is firing on the exhaust and power stroke of matching cylenders.
i know this has been said before but this realy is a crap way to go about fixing spark problems.
firstly you get a break down of spark by having high tensile leads. coil packs are right on the spark plug.
having the coils mounted on the firewall is going to induce more heat than the coil packs would get. nissan designed coil packs to sit where they do and they didnt expect someone to9 mod their engine 17years later and expect them to hold up to it. the coil packs are mounted at the front of a vn commo so they get cooling from the rad fan.
oh i am sure you know anyway. just get some spitfires. slide and croyden are in a bidding war at the moment at having the cheapest spitfires in aus. you could get a set for $500. that cheap. just do that.
ive been running el coil pack on my car with leads for some time now, spark jumps as far as the grand canyon, its up to you. spend the $500 for a bolt in coil pack that looks neat and can run std dwell, or bolt in a diff pack with leads and run more dwell= bigger charge and greater spark therefore better burn and more power is made, they f**kout due to the heat from being bolted to the cylinder head, i can guarantee you mounting it on the firewall would be not as hot for the coil. ive seen the el pack on rb26 t88 make well into 700bhp with no issue's std ignitor. however this was dyno time only, dont know how long it lasted this way.
 Share
    • People still have Skylines? I thought they're non-existent now.
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
