There are a couple of threads on here on how to do it with different coilpacks. Unfortunately the igniters dont handle it so well, as these coils have a much higher current draw, and th other problem is the ignition dwell time isnt suited to the se big coils, so they dont fully charge(saturate), hence you dont really get the full benefit of the big coil. I dont think ive ever heard of a splitfire dying, all the people that ive heard of having problems with them are because they fit splitfires to fix something which wasnt the coils.
ive seen splitfire coilpacks to suit my GTR for $350. if the cheapest you have seen is for $600, then id suggest you look a bit more. easier then modding the wiring looms and changing the igniter. My 2c anyway
Over here (in Malaysia) we use Mitsubishi 6A12 (2.0 V6) coilpacks due to the lack of reliability of stock RB coils. But we use Megasquirt instead of stock ecu or Power FC... So far only 1 or 2 cars used this setup (experimental stage) and so far there's no problem...
how about hyundai sonata coilpacks. the 3 packs of 2 coils if you know what i mean. like the commodore ones but for a hyundai
thanks for ideas but to keep to a tried and true type msg, also running fairly stock so adjusting recharge wont really be a major issue, so ill just use rb ignighter and VL coils, ill do a lil writeup after as well to help ppl in my situation later on
hey man,
parts needed:
VN Coilpack(the square type one, or the round, i've got the squarer one, because it looks better against my firewall)
VL set of sparkleads, shouldn't be too much or mix and match your own :fakenopic: just get the NGK or Eagle ones from supercheap
use a VN coilpack(Block of three coils with 2 spark leads on each side)
they are round $60-80 new i think? try the local holden dealer
sell your old coils for whatever yuo get for them, usually $20 each or so(here in NZ anyway, not much because they are poo)
keep the coil loom, cut the wires at the end, label them all though :) for each cylinder, then wire them up, i think it goes 1/6(first coil 2/5(second coil) 3/6(third coil)
It'll make it dead easy to change sparkies as well :rant:
I think if you want to use the original VL coilpack, you'd need some way of firing it? because it's dizzy standard isn't it? not sure if an ignitor would work in that sense, although it could do
Ah thankyou thankyou thats exactly wat i was looking for, VN ones not VL would be the go
the ignitor isnt really an issue yet
Like before ill do a writeup with photos when i do it
if the ignitor cant handle the current draw, what about relays? 6x GT40's with relays direct to the battery, would be ideal wouldnt it?
and on that note, what about adding capacitors etc?
Edited by SKiT_R31
this is a reply to the first post. vn coil pack fire both sparks together. on a vn it will be matched to one cylender that is on its power stroke and one cylender that is on its exhaust stroke to burn any unburnt fuel. it all helps with emissions. so you need to make sure yours is firing on the exhaust and power stroke of matching cylenders.
i know this has been said before but this realy is a crap way to go about fixing spark problems.
firstly you get a break down of spark by having high tensile leads. coil packs are right on the spark plug.
having the coils mounted on the firewall is going to induce more heat than the coil packs would get. nissan designed coil packs to sit where they do and they didnt expect someone to9 mod their engine 17years later and expect them to hold up to it. the coil packs are mounted at the front of a vn commo so they get cooling from the rad fan.
oh i am sure you know anyway. just get some spitfires. slide and croyden are in a bidding war at the moment at having the cheapest spitfires in aus. you could get a set for $500. that cheap. just do that.
ive been running el coil pack on my car with leads for some time now, spark jumps as far as the grand canyon, its up to you. spend the $500 for a bolt in coil pack that looks neat and can run std dwell, or bolt in a diff pack with leads and run more dwell= bigger charge and greater spark therefore better burn and more power is made, they f**kout due to the heat from being bolted to the cylinder head, i can guarantee you mounting it on the firewall would be not as hot for the coil. ive seen the el pack on rb26 t88 make well into 700bhp with no issue's std ignitor. however this was dyno time only, dont know how long it lasted this way.
    • The cam I am actually putting in (a few posts up) is actually smaller than my current one. At least duration/overlap wise. All the chop stuff I hear just sounds like an engine running badly, because it is. I then envision driving it around in 1st gear and being massively sad about it bucking to the beat of said chop. There is an idle video of someone with a similar cam floating around the internet, but mine is a custom cam (so is his) so it'll never be the same, plus the fact exhausts are entirely different. What I want to do is put some bullet mufflers/race mufflers in to replace a couple sections straight pipes that currently replace the two extra cats that I don't need. But this is even further down the line!
    • I can tell you now, when the bracket that the little hydraulic ram attaches to snaps, with a subframe, and V8 from an AMG C63 on it, it sounds like someone letting shotgun off right beside you. It leaves your ears ringing, and a huge thankfulness that you never ever put a body part under something heavy that's only supported by a hydraulic lift...
    • Still not a guarantee fix. I used a high quality butyl-mastiq (the black goo that's not really silicone nor polyurethane, same stuff they use from the factory that just spreads out like melty cheese), and I still get lots of water on both sides of the trunk when raining or washing the car. I also suspect the factory spoiler rubber gasket might not be sealing well, so I'm thinking of adding a thin layer of grey silicone around the bolt holes on both sides and see if that's where it also leaks from. The biggest issue is that these cars don't come with a drain hole on each side like other coupes and hatchbacks.
