There are a couple of threads on here on how to do it with different coilpacks. Unfortunately the igniters dont handle it so well, as these coils have a much higher current draw, and th other problem is the ignition dwell time isnt suited to the se big coils, so they dont fully charge(saturate), hence you dont really get the full benefit of the big coil. I dont think ive ever heard of a splitfire dying, all the people that ive heard of having problems with them are because they fit splitfires to fix something which wasnt the coils.
ive seen splitfire coilpacks to suit my GTR for $350. if the cheapest you have seen is for $600, then id suggest you look a bit more. easier then modding the wiring looms and changing the igniter. My 2c anyway
Over here (in Malaysia) we use Mitsubishi 6A12 (2.0 V6) coilpacks due to the lack of reliability of stock RB coils. But we use Megasquirt instead of stock ecu or Power FC... So far only 1 or 2 cars used this setup (experimental stage) and so far there's no problem...
how about hyundai sonata coilpacks. the 3 packs of 2 coils if you know what i mean. like the commodore ones but for a hyundai
thanks for ideas but to keep to a tried and true type msg, also running fairly stock so adjusting recharge wont really be a major issue, so ill just use rb ignighter and VL coils, ill do a lil writeup after as well to help ppl in my situation later on
hey man,
parts needed:
VN Coilpack(the square type one, or the round, i've got the squarer one, because it looks better against my firewall)
VL set of sparkleads, shouldn't be too much or mix and match your own :fakenopic: just get the NGK or Eagle ones from supercheap
use a VN coilpack(Block of three coils with 2 spark leads on each side)
they are round $60-80 new i think? try the local holden dealer
sell your old coils for whatever yuo get for them, usually $20 each or so(here in NZ anyway, not much because they are poo)
keep the coil loom, cut the wires at the end, label them all though :) for each cylinder, then wire them up, i think it goes 1/6(first coil 2/5(second coil) 3/6(third coil)
It'll make it dead easy to change sparkies as well :rant:
I think if you want to use the original VL coilpack, you'd need some way of firing it? because it's dizzy standard isn't it? not sure if an ignitor would work in that sense, although it could do
Ah thankyou thankyou thats exactly wat i was looking for, VN ones not VL would be the go
the ignitor isnt really an issue yet
Like before ill do a writeup with photos when i do it
if the ignitor cant handle the current draw, what about relays? 6x GT40's with relays direct to the battery, would be ideal wouldnt it?
and on that note, what about adding capacitors etc?
Edited by SKiT_R31
this is a reply to the first post. vn coil pack fire both sparks together. on a vn it will be matched to one cylender that is on its power stroke and one cylender that is on its exhaust stroke to burn any unburnt fuel. it all helps with emissions. so you need to make sure yours is firing on the exhaust and power stroke of matching cylenders.
i know this has been said before but this realy is a crap way to go about fixing spark problems.
firstly you get a break down of spark by having high tensile leads. coil packs are right on the spark plug.
having the coils mounted on the firewall is going to induce more heat than the coil packs would get. nissan designed coil packs to sit where they do and they didnt expect someone to9 mod their engine 17years later and expect them to hold up to it. the coil packs are mounted at the front of a vn commo so they get cooling from the rad fan.
oh i am sure you know anyway. just get some spitfires. slide and croyden are in a bidding war at the moment at having the cheapest spitfires in aus. you could get a set for $500. that cheap. just do that.
ive been running el coil pack on my car with leads for some time now, spark jumps as far as the grand canyon, its up to you. spend the $500 for a bolt in coil pack that looks neat and can run std dwell, or bolt in a diff pack with leads and run more dwell= bigger charge and greater spark therefore better burn and more power is made, they f**kout due to the heat from being bolted to the cylinder head, i can guarantee you mounting it on the firewall would be not as hot for the coil. ive seen the el pack on rb26 t88 make well into 700bhp with no issue's std ignitor. however this was dyno time only, dont know how long it lasted this way.
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
    • Sorry, I wasn't very clear.....just that the standard injectors are apparently good over 600rwhp/450rwkw which you won't get to on standard turbos anyway.....they are much better sized from factory than we are used to in RBs.
    • I'm not sure where you are, but United Terrey Hills has E85.
