Vn Coilpacks On Silvertop Rb20det
Quigga
 Share
Seen it done plenty of times, usually with bosch GT40's (essentially the same thing)
wiring is extreemly basic, just extend and add the right plug
not too sure how the ignitor would hold up.....can't see there being a problem though
There are a couple of threads on here on how to do it with different coilpacks. Unfortunately the igniters dont handle it so well, as these coils have a much higher current draw, and th other problem is the ignition dwell time isnt suited to the se big coils, so they dont fully charge(saturate), hence you dont really get the full benefit of the big coil. I dont think ive ever heard of a splitfire dying, all the people that ive heard of having problems with them are because they fit splitfires to fix something which wasnt the coils.
can u upgrade the ignitor pack to handle the coil packs? is there anything out there that is suitable
lol thats my question :ninja:
ive seen splitfire coilpacks to suit my GTR for $350. if the cheapest you have seen is for $600, then id suggest you look a bit more. easier then modding the wiring looms and changing the igniter. My 2c anyway
Over here (in Malaysia) we use Mitsubishi 6A12 (2.0 V6) coilpacks due to the lack of reliability of stock RB coils. But we use Megasquirt instead of stock ecu or Power FC... So far only 1 or 2 cars used this setup (experimental stage) and so far there's no problem...
how about hyundai sonata coilpacks. the 3 packs of 2 coils if you know what i mean. like the commodore ones but for a hyundai
thanks for ideas but to keep to a tried and true type msg, also running fairly stock so adjusting recharge wont really be a major issue, so ill just use rb ignighter and VL coils, ill do a lil writeup after as well to help ppl in my situation later on
hey man,
parts needed:
VN Coilpack(the square type one, or the round, i've got the squarer one, because it looks better against my firewall)
VL set of sparkleads, shouldn't be too much or mix and match your own :fakenopic: just get the NGK or Eagle ones from supercheap
use a VN coilpack(Block of three coils with 2 spark leads on each side)
they are round $60-80 new i think? try the local holden dealer
sell your old coils for whatever yuo get for them, usually $20 each or so(here in NZ anyway, not much because they are poo)
keep the coil loom, cut the wires at the end, label them all though :) for each cylinder, then wire them up, i think it goes 1/6(first coil 2/5(second coil) 3/6(third coil)
It'll make it dead easy to change sparkies as well :rant:
I think if you want to use the original VL coilpack, you'd need some way of firing it? because it's dizzy standard isn't it? not sure if an ignitor would work in that sense, although it could do
Ah thankyou thankyou thats exactly wat i was looking for, VN ones not VL would be the go
the ignitor isnt really an issue yet
Like before ill do a writeup with photos when i do it
if the ignitor cant handle the current draw, what about relays? 6x GT40's with relays direct to the battery, would be ideal wouldnt it?
and on that note, what about adding capacitors etc?
Edited by SKiT_R31
this is a reply to the first post. vn coil pack fire both sparks together. on a vn it will be matched to one cylender that is on its power stroke and one cylender that is on its exhaust stroke to burn any unburnt fuel. it all helps with emissions. so you need to make sure yours is firing on the exhaust and power stroke of matching cylenders.
i know this has been said before but this realy is a crap way to go about fixing spark problems.
firstly you get a break down of spark by having high tensile leads. coil packs are right on the spark plug.
having the coils mounted on the firewall is going to induce more heat than the coil packs would get. nissan designed coil packs to sit where they do and they didnt expect someone to9 mod their engine 17years later and expect them to hold up to it. the coil packs are mounted at the front of a vn commo so they get cooling from the rad fan.
oh i am sure you know anyway. just get some spitfires. slide and croyden are in a bidding war at the moment at having the cheapest spitfires in aus. you could get a set for $500. that cheap. just do that.
ive been running el coil pack on my car with leads for some time now, spark jumps as far as the grand canyon, its up to you. spend the $500 for a bolt in coil pack that looks neat and can run std dwell, or bolt in a diff pack with leads and run more dwell= bigger charge and greater spark therefore better burn and more power is made, they f**kout due to the heat from being bolted to the cylinder head, i can guarantee you mounting it on the firewall would be not as hot for the coil. ive seen the el pack on rb26 t88 make well into 700bhp with no issue's std ignitor. however this was dyno time only, dont know how long it lasted this way.
 Share
    • What are you doing with the car? street car or race car? People get hung up on the squat of the s/r chassis rears. There is positives to the squat if a car is setup and driven correctly for it (correct ride height, spring rate, alignment, damper valving). Generally just lengthen the rear traction arm by 5-10mm and that will help the squat and bump steer too. You are also correct with the roll centre too. This too also needs to be adjustable if you start messing with suspension geometry.   Having done quiet a bit of testing on race cars this year in regards to rear squat, I've seen some big positives from it in regards to drive off corners and traction.
    • I find I am using the MX5 for everything except long overnight cruises with Jackie, or, if picking up the kids to go somewhere, the SS has so much more room inside, and is much more comfortable if your going to be doing Hwy driving for 6-8 hours And the MX5 isn't bad in stop go traffic for a manual transmission car, whilst the clutch kit has been upgraded from stock, it is still light, and also not having a stupidly light flywheel in it helps as well, I've spent alot of time sitting on the M5, M4 and M7 stuck in traffic when plodding around the Greater Sydney Region in it Another benefit is MX5's are not really a car that gets stolen, you can pretty much park it anywhere, and it will still be there when you return
    • I can totally get why you like it for that sort of commute. I was thinking BoganDore because it's such a lazy drive, for things like stop start traffic.   I used to do over an hour in stop start shit from one side of Bris to the next, twice a day. My choice of car was larger displacement, with an auto. Basically for torque in low rpm/very low speed, and no clutch pedal. But loved a fun manual for the weekends, which the partner has (plus had the LandCruiser too for other fun drives). I now have an EV as a work car, and I tell ya what, ultimate daily driver, especially if youre out of energy, like I often am after work. I don't even need to touch the brake pedal   That said, I'm presently rebuilding the Liberty GTB to get it setup for weekend drives and track abuse! So small high revving turbo engine with 6 speed cog swapper!   But for your style of commute, I'd probably take the MX5 too!   For those choices, I'm ignoring fuel economy. Because I know how atrocious V8 daily life is for fuel from when I used to daily a manual SS, ha ha. Hence why I know I love the daily rumble of a V8
    • II know what u are saying after 9 years of hibernating my stock engined  110,00km gtt I got it registered 2 weeks ago. Took it for a drive a couple of days ago and some fresh bp fuel, I just couldn’t stop grinning and dreaming of when I will start my build thread. its just such a primal man feeling many forget to enjoy I wish u so much enjoyment with your little racer mate
    • People just don't understand how good MX5's actually are and how fun they are to drive, park, manuever. You feel like you have got some fun cheat code, while everyone else is sitting in their luxobargeSUV like normies who missed the point of living. It really is that noticable. As long as you/your stuff fit, and you're comfortable (they are), a MX5 is the best car on earth to daily around.
