the 'bunny hop's probably you hitting the overboost ignition cut
get one of those cheap pneumatic boost controllers (or splurge on a big dollar elec one if you prefer)
cheers mate, ye im actaully gonna get a boost controller in a few weeks it was meant to be done on the day i got my fmic but they had to leave it another day.
https://www.sau.com.au/forums/topic/177573-overboosting/#findComment-3242521
Uhhh ok I dont see how a boost controller will help with overboosting if you dont have one on there already...
Firstly, what sort of car? How much is it overboosting by? And did you change anything else or only the FMIC?
A boost controller wont help at all if you have no boost control currently (ie its just the wastegate), as a boost controller simply cant make the wastegate open at any lower pressure than where the spring opens.
A bleed valve quite literally 'bleeds' some of the pressure so the wastegate doesnt see it, theres no way of making the wastegate see *more* pressure so that it opens sooner and therefore runs lower boost.
https://www.sau.com.au/forums/topic/177573-overboosting/#findComment-3242872
s15, dont know how much but all i know it passed the 1bar, i got zorst, pod, fmic, new clutch that has slipped but fixing it again.
If you've done a FMIC, make sure you have some sort of feed still going from a pressure source back to the wastegate.
Not pressure feed = no boost control
That would be my first place to look.
which vacume do i need to look at, dey all look like they r in place
https://www.sau.com.au/forums/topic/177573-overboosting/#findComment-3243296
On the passenger side suspension tower, you will have a stock boost controller solenoid.
this will have hoses comming in and out of it.
one goes to the wastegate actuator and the other goes to the intercooler piping.
when stock, one of those pipes also has a tiny little restrictor in it to make the boost stay at 7psi.
so..
when you got a fmic installed, if they didn't connect the hose to the wastegate actuator or to the NEW intercooler pipe, you will have no boost control, therefore the wastegate will stay shut causing all the exhaust gases to go through the turbine wheel, making massive amounts of boost.
If it is all connected, they may have changed the hose or hoses from boost controller to new ones to fit the new piping and therefore the restrictor is gone and now you will have about 14-15psi if I remember correctly on my old S14..
so in a way, a new boost controller will solve your problem..
https://www.sau.com.au/forums/topic/177573-overboosting/#findComment-3243834
    • So, how do you feel about the Frenchys surge tank setup @Duncan? Have you had a chance to try it out more? The sketchy wiring in my fuel pump setup has decided to melt and die and I'm looking for a solid replacement now. My fuel hat is toast so the Frenchys kits providing it all look promising.
    • Yeh... literally every time i jump on a forum, see an instagram post or see an engine bay at a car show, i get an idea and add it to my 'to do' list. So what started off as, hey can u just make a couple of intake hard pipes because my dumbass bought the wrong apexi kit, blew out into a 2 week job including braided brake lines & custom bash kit for the front lip haha.  Getting Luke from A4E engineering to make a full custom exhaust with a controllable aes dump valve so i can actually switch between quiet and loud, because right now its just loud all day every day. Then after that go and get the tune redone flex e85 & 98 as i get bugger all milage from e85, makes going for longer drivers difficult
    • Car looks clean as. You ended up getting quite a bit done 😂  So what's the plan for the exhaust?
    • The only Neo rods that were any different to any other RB25 rods were the DET ones, and they were the same as RB26. Here is a Neo DET rod. O5U part number visible. Here is a post in a thread here on SAU with evidence from someone who has done this before. There are photos in the thread of normal RB25 rods.
    • Sure, but why assume that will be the case forever? And why assume you'll be able to do an oil change to swap back to a stock drain bolt before that happens? And does it even matter when I change the oil at fairly short intervals? Life can be funny sometimes and unexpected things can happen. Like breaking a collarbone so you can't do any work on your car for a few months but the oil change is due so you have to take it to somewhere and hope they don't do something stupid like stacking the new drain plug washer on top of the old one.
