Hey guys just wondering im lookin at purchasing one of the above for my r33 gtst. The specs of my r33 are fmic, boost controller running 10pis, pod and full exhaust.
Using the above and with one of the for mentioned piggy back systems Im hoping to get around 200kw atw.
JUst wondering which one is best suited? Which ones have you all used? Wat are you experiences? and as far as value for money what the best?
https://www.sau.com.au/forums/topic/177591-safc-e-manage-or-gizzmo-camfc/
find some tuners near you or on the forums and see what they prefer and use
they will have good hands on experience using what they know, be sure to cover a few so you dont get a biased opinion.
i dont think the gizmo camfc will do what u want the safc has proven results over and over and should get you 200rwkw without an issue
i think it would be cheaper than the emanage too
lookin at around 500-600 inc tuning for the moment so power fc is out of the question.. I can get an emanage for around 300-400, safc 1 for around 200, and safc 2 for around 200-250, a camfc is around 250 also. SO I reckon 200 for tuning should be enough.
If that is ur budget get a SAFC II, cost about 250 second hand, if u can get it cheaper then all the better. I payed $150 for the tune. Don't know what rwkw the mods u have make in ur car now but they r the same mod I had and I got 20rwkw from a SAFC II tune. If ur pushing 160-170 already then u should get close to 200rwkw but dont be dissapointed if u dont get it lol. I was told to expect 160 rwkw and only got 150, i was dissapointed.
Liam
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
    • Thanks Paul I reached out to Autotainment but they no longer work on JDM cars as the guy who used to do the work moved on and is no longer doing that kind of work. I am talking with Level Up Audio though.
