Wrecking R33 Skyline Series 1 Colour is Dark Grey everything must go. Car is being wrecked in Penrith some parts available in Hornsby.
Pick up welcome
No Engine or gearbox available.
Engine Parts
gtr diff cv`s hubs 500
Intercooler 400
X Member and Engine mounts to Suit Toyota 1JZ 400
Exhust 4" 400
Tail Shaft 200
Radiator 100
Manual Clutch Pedals Slave Cylinder 150
Radiator 100
Brake Booster 50
Interior
Boost Gauge in instrument cluster 300
Window Switches 150
Electric Window Motors Pair 150
Rear Seat 100
Steering Wheel 100
Door Skin 100
Dash Surrounds 100
Power Windows 100
Carpet 50
Hand Brake 50
Glove Box 20
Rear View Mirror 20
Panels
GTR Indicators 250
Bare Shell 200
Front Fender Panels 200
Boot Lid with Wing 150
Boot Lid 100
Right Door 100
Fuel Tank 100
Standard Indicators (No Chips) 100
Rear Lights 100
Right Mirror 80
Windows 50
Suspension
SSR racing 7kg wheel new rubber 1500
Standard Suspension 300
Standard Wheels 200
Lower Control Arms (Both) 200
Steering Arms 100
hicas lock cost 50
Picture are located here
Pictures
Sold
Bonnet
Front Bumper
Lights
Rear Skyline writing
Edited by Geoff897
https://www.sau.com.au/forums/topic/177600-wrecking-r33-skyline/
Sorry no ash tray
car was manual
I have the boss and steering wheel Front rotors are the standard non slotted rotors
Front bar $150
Ill have to check is the space saver was in the car. will check on the weekend.
All PM replied to, as i have had lots of PM about the coilovers ill check the condition of these on saturday and update this thread.
Geoff
Hey Geoff...
Il grab that Grill off you too.. not the standard one the GTR style one...
Not going to make it there today but how bout tomorrow night .... bout 5.30ish???
btw Happy Birthday :sorcerer:
i was after a complete gtr rear cradle, is that what u have?
where u located
Location in Hornsby and some parts are in Penrith.
PM me you phone number and ill see what i can do.
Thanks Anna
Ill hold the grill for you.. Let me know if you want those Tail lights and Wheels.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
