hey guys
Just wondering if anyone can give me advice on this problem i have.
I have a r33 s2 gtst with 3.5 exhaust, fmic, hks stainless steel pod, stock boost, 60 000km on the clock
The car ran beautifully and 2 days ago i installed a box for the pod filter.
Car still ran fine after this install
Then this afternoon i gave the car a few good runs and it started to make popping noise from the exhaust.
This happens under hard acceleration and only in the rev ranges of 4000 to 5500.
I have read many posts on this problem but i still have a few questions.
1. has anyone else had this problem runing stock boost?
2. do you think that because the filter is getting cooler air now that its causing the problem?
any advice would be greatly appreciated.
Cheers Simon
https://www.sau.com.au/forums/topic/177605-r33-s2-misfiring/
shouldnt be because of making the airbox, all that would do is increase efficentcy a.k.a cooler air better combustion.....
u may be getting a little boost spike due to the cold air but it shouldnt be much on stock boost, hence u can rule out boost cut....
make sure u havent damaged the afm or the plug/lead around the area
thanks dude
i`ll check the plug and afm as well, great care was taken when removing it but will double check
one thing i did notice about the afm was that the resistor wire looked like it had a bit of gunk on it,
do you thing i should hit it with the carby cleaner?
Cheers Simon
i have the same problem aswell!! its been driving me crazy the past few weeks,
i have put new sprak plugs in n it done nothing, i even put a tank of v-power in a bottle of octane boost in to try n see if it was cause of low octane but still does it..
im just about to go out n buy a set of coils cause i cant think of anything else to change or check
any1 have any other help?? im sure other ppl have this same problem aswell
i can see that theres a few of us on the same boat.
Hey Buddy, did you regap your spark plugs at 0.8mm before putting them in?
and what type sparkies did you use?
R33 S2, let us know if the new coils cures it.
I was also looking at a set of splitfire coil packs from hi octane racing for 600, is this price reasonable?
Cheers Simon
Its coils.. I fixed it with a power fc and plugs gapped to 0.6. New coils coming soon.
the air box issue doesn't surprise me as i run one and had it BAD! It was always worse in the colder night time temperatures.
Cheers Simon
sliding performance on these forums sell them delivered for 515!
http://www.skylinesaustralia.com/forums/in...howtopic=153971
ill let ya know how i go!
hey guys
pulled out my plugs today.
the car had a set of hks plugs through it and the tips of the electrode are still pointy and shinny.
had a quick look at the coils and they look pretty good on first inspection.
will have a proper look at the coils tomorrow in the day light.
Also going to put a set of new plugs gapped at 0.8 or 0.9 tomorrow.
So i`ll get the plugs in and re install everthing tomorrow night and hopefully it should run sweat.
If not then a set of new coils are on the table.
Cheers Simon.
hey guys
Cheers Simon
yeah, i had the exact same problem on my r33 with similar mods. i replaced all of my spark plugs and now it runs like a dream.
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
