95' R33 GTR GODZILLA Twin Turbo 4WD
Approx 100,000kms (Aftermarket Dash With 27,000kms)
R34 NUR SPEC Ball Bearing Turbos (Bigger then N1's)
Aftermarket Cams
SPLITFIRE Coil Packs
HKS Coilover Suspension
18" x 10" GOLD BBS Wheels
Brand New 275/35/18 FK452 Falken Tyres
Slotted BREMBO Brakes With Air Ducts and Air Guides
Heavy Duty Clutch (very easy to drive)
JASMA Exhaust with APEXI Hi Flow Cat
NISMO Rear Suspension Arms
HKS EVC Dual Stage Electronic Boost Controller
NISMO 320km White Dash Cluster
NISMO White Triple Guage Cluster (Front Torque, Oil Temp, Boost)
GREDDY Boost Guage
GREDDY Water Temp Guage
GREDDY Oil Pressure Guage
GREDDY Oil Temp Guage
HKS Pod Filters
Polished Oil Catch Can
Front Strut Brace
Rear Strut Brace
NISMO Clear Side Indicators
IMPUL Racing Gear Knob
Power Steering
Climate Control
Central Locking
Power Windows
Power Mirrors
Driver's Air Bag
First Owner In Australia. Serviced Every 5,000kms.
Very Good Condition. Very Quick.
Drives and Handles Very Good. Buyer Will Not Be Dissapointed. First to Drive will Buy.
$29,500 O.N.O. 0400696678
https://www.sau.com.au/forums/topic/177612-r33-gtr-with-mods/
nice gtr mate, what if any after market ecu are you running? and how much rwkws? thanx carl.
thanks mate. running factory computer. made 280rwhp with 800Nm of torque on 16psi. but think dyno may of been out cause everyone says it goes very hard. just a good combo of turbo's and cams done in japan. factory computer richens right up on boost so is very safe. my old 33 gtr had N1's and Power FC and this one goes alot harder.
thanks.
Edited by BIGPSI
    • There are several aftermarket options available, from not-too-painful moneyhttps://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35 and  https://justjap.com/products/crank-motorsport-billet-rear-axles-fits-nissan-skyline-r33-gts-t-r34-gt-t?srsltid=AfmBOorQk4xkGUa98kO7v2ePLUiNt-HRrM2AwWNw9mbSIVE1ujBVwY__, all the way up to The Driveshaft Shop https://driveshaftshop.com/skyline-cv-axles/
    • Yeah based on old XRC5964S specs, it looks to be roughly GTX3576R sized? But this 5964S compressor will flow 90lb airflow somewhat similar to the compressors in both the GTX3584RS or G35-1050.. I fully expected the 0.64 rear A/R to choke up top - seems way too small from typical convention - but these are seemingly beneficial over the prior 0.82 results.. Be interesting to see if he comments on the EFR question in that thread - he mentioned in a prior video that BW EFR's were the "cats pajamas 10 years ago", but by the sounds of things all his kits have been using Xona for quite a while now.
    • Yeah it’s still got the oem manual gearbox and clutch, only kinda mods are a blow off valve, coil overs, and a aftermarket intercooler. Also had it for about 2 months now with a lovely midnight purple paint on it.
    • Yeeeppp, been following a lot of the testing on the latest Xona stuff and there are some mental results.  He also went over 1000hp @ 4 hubs on his Mainline with a XRE6364S (63mm) which was also well into the 20psi range before 4000rpm on a 2.5. Crazy stuff. Fwiw the XRE5964S is basically the modern equivalent of their old HTA3582 - would drive nicely enough on an RB25 or 26, but proven capable of a huge amount of power if you want to spicy with rpm tho even at sane boost levels will make stout numbers
    • The axels in my R33 seem tired, and have a bit of play in them. I cannot find any new of course, not interested in buying used, but I am looking to see if anyone can identify some cross compatible axles. In the states I have seen suggested for S chassis the J30 axles, however for the skyline (as best I can tell) the lengths are about an inch off (2.5cm) on both sides. R33 my measure L 22" R 24.5" GPT L 22.5" 24.25" J30 L 23.5" 25.5"  so shaft length is probably an inch wider. Not sure if someone has another still remanufactured option besides the J30. I figured worst case I can buy a pair tear them down and swap the center shaft. My other option was reaching out to GSP to see if they cannot piece together a set, since the axle stubs are still manufactured, I wouldn't think it be that hard to find a shaft or make a shaft work.
