Not sure about the R32 but I assume it's similar to an R33.
When i bought my harness i got some eye bolts with it. You replace the rear seatbelt bolts (inbetween the upper and lower cushions) with the eye bolts. And then same with the front bolts, usually where the front seatbelt is bolted in, replace with eye bolts and the harness can clip on and off there with ease. Do a search on these forums, there is info about it.
  • 4 months later...
sorry to thread mine, but can the rear straps be bolted anywhere other than the rear seatbelt bolts? ie, so i dont have to muck aroundif i wanna put people in teh back seat...
The answer is no. The rear seatbelt points are the only strong enough "stock" places to utilise (DO NOT USE THE BABY RESTRAINTS!). Your only other option is to have some sport of custom made harness bar built. This by far is a much better option if your willing to spend the $$$. Using the rear setbelt bolts are way borderline on acceptable harness angle from your shoulders... under a heaving impact your spine will be compressed!
the harness most defintly should come of your shoulders completely horizontal, although a slight down angle is still ok. Ive had a harness bar built which cost me about $500, althuogh it does still require the removal of my back seats to bolt in. At the end of the day how hard is it to remove your back seats? In my 33 its 2 bolts for the back rests and 2 bolts for the seats? pretty simple me thinks.
  • 4 weeks later...
yep very true, I think 15 degrees down from horizontal is the maximum allowed by CAMS, I hit a wall at 90kmh and my 4 pt was bolted to the rear seatbelt eyelets, back hurt for around 2 weeks
    • One other question, is there a chance that changing the idle speed can lead you down a rabbit hole and is the reason the tuner didn't touch it? Reason I ask is because if that's the reason the tuner avoided it then I probably shouldn't be touching it lol.
    • Pfft. As if I'd ever point a high pressure washer at my car.
    • The nature of my commute has changed. Way back then it was traffic lights all the way, for ~28km. It sucked. When they finally stitched the expressway together I could do a good 15+km of it at a steady 80-100 with no stopping. That alone has gotten me down to flat 10s. Prior to that it was mid-high 10s. I can't remember the delta that I saw when I got the idle down. It was only ~150 rpm, because the idle speed was never terrible, but for the delta in consumption to be noticeable it would have had to have been at least 0.2-0.3 L/100km - which is not to be sneezed at when it comes for absolute free. It's only about 50L per year, but that's ~$100. A few extra pizzas is always welcome. Note that I have a record of every tank of fuel that has ever gone through my car except for a handful put in by someone else, like my mechanic. I can show you the difference between stock RB20 and tuned RB20, stock RB5Neo and tuned, winter and summer fuel blends, winter and summer fuel blends when the ambient temperature is not appropriate for the blend, working O2 sensor, blown O2 sensor, boosting f**k out of it and frightened to boost it because it is pinging, and so on. OK, I probably can't do all that now with 100% clarity - but at the time when any of those things were in event, you could see it in the records. There's 25+ years of simple tank after tank records, so you have to look for landmarks to work out approximately how old any single record is. What's really important is the meta data and that lives in my head.
    • If you're claiming the issues are not skyline specific, then either the USA is living in the 90s / early 2000s, OR you have the issue of "survivor bias". Which is you're mainly hearing and listening to those with terrible experiences, and haven't found the guys who have cars with good decent builds and no problems. It happens in AU too, that plenty of people keep having issues, and they keep going to the workshops that are known to be shit "because I read on the internet". Even worse, are those who keep posting on the internet as though they know for a fact what something is, when they've never touched/looked at said item in their life, and again are making assumptions, based on something they read, or because it's a certain way in other cars. It's even funnier when those same people debate the facts with the people who've lived and breathed this stuff for over 15 years. Example, I've had someone tell me you can't do something with a Skyline, because they read it on the internet, except I can tell they're wrong, as I did that exact thing back in 2008 with my Skyline.
    • The funniest part I saw, was someone would bitch and moan on FB about something, Andy would be the one to respond, asking for more info, if he could contact them, what the engine setup is, what their config file was, and 95% of the responses were people just going "der! It doesn't work" and Andy going "What doesn't work?" And then going "The firmware!" And they'd go around in circles as no one could ever give information, and Haltech couldn't fault things on the bench, (especially when people wouldn't give any specifics).   Many moons ago, when Andy was back at e420c stage, he reached out to me, and asked me to test different plug and play looms for him (already had an e420c in the car on his V1 PNP loom). And he kept asking me, as I was competent enough to be able to give him some specific feedback on what was/wasn't working, how to replicate the faults etc, and work through things with him. Most people are terrible at answering the questions they're asked, or being able to provide quality feedback other than "it doesn't work".
