Hey All.....
Well the other night i was coming onto the highway.... gave it a boot in 1st and noticed that it kinda cut out at about 6grand...... so drove normal in 2nd.. and then cruised at 80.... dropped back to 3rd and tried to give it a bootfull and the car cut in and out voilently making the car surge forwards and backwards....
took my foot off the gas and just cruised... took it easy for 5min and it didnt do it again...
i had 1/4 tank of petrol although its only ever cutout when ive been sitting on empty and boosting hard... no error codes and boost was normal on 18psi......
it rather worried me and it hasnt happened since so im not that worried but wondering if anyone can shed some light on it... maybe a sensor playing up, possibly ignitor on its way out? CAS? ... i dunnno!
mods
spitfires, highflow, injectors, retune, the lot... all supporting mods etc....
Weird thing is it hasnt done it since, and has never done it before this so im guessing there has to be something somewhere
Any thoughts...
Thanks
https://www.sau.com.au/forums/topic/177668-massive-power-loss/
Hey buddy I had the exact same thing happen to me, usually after giving it a bit of boot. Tried everything to fix it, I can tell you that it wasn't the ignitor, injectors, fuel pump, or the air flow meter but a week later I had the CAS fall off and the resulting error in the timing killed my turbo, so check it out before this happens. I also checked for boost leaks and again it was fine.
My advice, check the CAS incase it's the same as mine.
i would also say CAS, but if that is ok maybe the ignitor or AFM. if it has gone away it may be a bit hard to find the problem.
yeah i was thinking cas or afm.... ill check them both out and give the afm a clean..... i was almost thinking fuel pump was on its way out (bosch 019) but it would keep doing it if it was......
Any other ideas? or tests i can do?
Well looks like i might have to start looking for a CAS sometime soon... although it only did it briefly and hasnt done it at all since, how much am i looking at for a good used one Blitz?
Ive got a Bosch 019, pretty much exactly same as 040 just slightly lower flow rates... but still goot for 300rwkw or so... ive only had a surge problem when its been ON empty, not with 1/4, thought it might have been a cause thats all...
I had a similar problem with my car.....it would run fine one minute then lean miss/surge the next as you're cruising. Scoped the AFM's with FC-Datalogit, I have a power FC, and found 1 of the afm dropping out to 0.3v or so then back up to normal.
Resoldered the 4 pins under the AFm lid and problem fixed. The signal wire pin had dry jointed to the terminal for the plug. It looked soldered but wasn't.
Simple fix.
Mike
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
