Heavier valve springs, solid buckets, bigger cam in just the head. though those mods can cost a fortune. what kinda money are you wanted to spend will determine what mods you can do.
forgies and stuff to start things off, I suppose.
https://www.sau.com.au/forums/topic/177682-head-work/#findComment-3245371
5k for the bottom end also?
Won't get you much at all. Especially if your paying some one labour to remove/install.
5k for the head reco and cleanup will get you quite a bit. :D
Depending on goals; I would have the head tidied up and reco'd (~1-1.5k); while your there throw a set of heavier springs at it (~$300) and block off the front oil restrictor while installing a 1.5mm in the rear (as per SK's recommendation).
Cams can come later if you don't have the $$ as they are an easy job to install.
Then its pretty well set for 20+ psi; all thats needed is a decent bottom end to hold the power.
https://www.sau.com.au/forums/topic/177682-head-work/#findComment-3245548
I see little point unless you are building a bottom end as the bottom end is going to let go and be on the limit before the top end.
In which case that puts you way over the 5k budget right there being a rebuild your looking at anywhere from 4-8k depending on what you want, whos doing the work, parts used etc etc.
So you wont have any spare change for the head.
There are plenty of threads on what it costs to make "XXX" power.
280rwkw isnt cheap, if you lunch a motor then your in strife.
Whats your overall budget? If you only have 5k i would look at your aims and peg them back to a more reliable and cost effective 240-250rwkw.
https://www.sau.com.au/forums/topic/177682-head-work/#findComment-3245671
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
