Try reseting the ecu... may do nothing, but its easy to do. It will make the car start learning its fuel mixtures etc again.
Do this by diconnecting the battery and then get in the car and turn all the lights on, your foot on the brake etc. This will drain the remaining charge in the system. Do this for about 5-10 min. Try pressing your horn. If it does nothing, your discharged. If it makes a sounds keep going a little longer :cool:
Once you've done that, reconnect the battery and test it out.
https://www.sau.com.au/forums/topic/177684-please-help/#findComment-3244026
Try reseting the ecu... may do nothing, but its easy to do. It will make the car start learning its fuel mistures etc again.
thank you :) I will give it a go and hopefully that works
https://www.sau.com.au/forums/topic/177684-please-help/#findComment-3244032
