On Sunday 12th August the Hobart Sporting Car Club and the Italian Car Club will be holding a day of Super Sprints at Baskerville Raceway.
This is a great day to thrash your car round a track and have some fun (roll cage is not mandatory)
I beleive there may be some drifting as well, GMB?
Trophies will be awarded for fastest lap times in various classes.
The cost is $60.00 and you must belong to a registered car club to enter.
Regards,
Rod.
  • Replies 43
  • 3 weeks later...
I had a good day once i got there, the track is completly diferent to Symmonds, but heaps of fun.
I somehow managed to get driver of the day, pretty stoked with that. And the other Ben (tas_180) got best drifter who drove of the day.
Well done, What times where you doing Ben, I read on n/s that Ben in the 180 did a 101???
So pi$$ed I had to work.
Leigh
i didn't see my last time sheet, but my best on run 2 was a 1:04.11. But on the last untimed run of the day i recon i was faster, i used diferent lines and gears.
180 ben was doing 1:01's, and so was the other GT-R.
Edited by sav man
I think a lot of people were very impressed with your efforts out there sav man considering you hadn't even driven the track before. Had some Great speed out of the sweeper then into turn 1. Was good to watch
Well done :nyaanyaa:
Thanks again for those tyres Ben, hopefully i can get them on the rear and allow me to use more than 1mm of throttle out of every corner ;).
For someone who hadnt driven on the track before you picked up the lines very quickly, you definately deserved that trophy mate. Racing against Rod's GTR makes me want a GTR now, damn torque monsters even in mild tune.
The pink XU1 (even though not original) would have to have been my favourite car out of the lot. MMmmm... :D
I didn't go but it seems that GT-R is starting to handle pretty well Rod. :D
Well done, some great times by the sound of it. Not sure I know who Tas_180 is but a great effort also!
Anyone have any official times? eg 1.01.?? (got to keep an eye on my competition ;) )
You guys entering the next hillclimb?
BTW there's an MCC super-sprint on the 19th (unless something's changed) so for those who didn't make it this time here's your chance... ;)
(I won't make this one either)
Tim.
Edited by roaldin
Tim.
My best lap was hand timed by the HSCC as 61.7 and by the old girl as 61.6. Rod was around 61 flat from memory.
My car will get smashed to pieces if i enter most hillclimbs. Dont plan on raising the car so dont think ill be seeing many hillclimbs anytime soon.
Wont be out next weekend either, car needs some TLC before it moves again.
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
    • I leant out the window recently and took a picture of this new WRX. It looked real damn fine in person. It's faster around a track (stock) than a (stock) GR Yaris. It's much more practical despite being heavier. It's significantly cheaper. This gen tunes really well, much better than others. .... I think they're probably a lot better than people expect.
