  • Replies 433
Posted Images
if enough people go in to make it $229, i'm in
I've added you to the list as a maybe
Come on guys!
Where else are you going to get ADR approved hoses this cheap !!!!!!
Someone with a 32 gtst volunteer their lines damnit! :sleep:
I actually came across this guy on ebay and he said he could copy my R32 gtst ones. My car is off the road at the moment, so im going to send my standard lines down for him to copy.
So he should be able to do r32 gtst lines after next week.
Shaun.
So these come 100% ready to install on the car? No d*cking around at all?
If so i'm in!
All you need to do is take off your old hoses, and put these straight on...
What car you need them for??
Due to increasing pressure from imported braided hoses, BrakeWest have decided to sell their ADR approved hoses for $195 including delivery.
We just need a minimum of 10 people....
Mate my car DOES NOT have abs.
If that makes a difference to my order.
Cheers
BrakeWest are getting samples of abs and non-abs gtst's.
They suspect there will no difference, but when they want samples just to confirm.
    • IMG_8641.mov     She doesn’t sound the best but starts with out using any gas now. I just ran some injector cleaner through her. started roughly the first time after adding it but gave it the beans slowly upto 4k, Must have cleaned a few cobwebs out. another step in the right direction for the sub
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
    • How much does the shifter move when the car is in gear with the engine off? If it is more than about 1cm you need to replace your shifter bush. Your shifts will just get crunchier, not faster, with a short shifter unless you also rebuild the whole box
