The GB will be closing this Sunday (25th November) for Christmas.
BrakeWest would like me to pass on their thanks to everyone who made a purchase.
This GB will re-open in Janurary next year.
:rofl:
damn, just missed out on this group buy. i'll definately be in for the next group buy in january for some brake pads for r33 gtst
  • Replies 433
Posted Images
Received my hoses today! ! !
I am very impressed with the quality of build and the custom black hoses with black end caps for my GTR are simply the best.
Thanks again Mark for your great service and a top product,
Good to hear mate !!
:rofl:
Very interested in a package for my 33 GTST although if cant get them within a few weeks please tell me and ill import endless SSS.
BrakeWest will be re-opening on the 7th of Jan 08, so you should get your package that week.
Is that too late?
Is that too late?
That might be ok will find out. Road use for me, so the 500c pads. Anyone experienced screaching or noise with QFM? I like quiet brakes. >_< Edited by Xizor
That might be ok will find out. Road use for me, so the 500c pads. Anyone experienced screaching or noise with QFM? I like quiet brakes. :)
I've only ever used the K750. They only ever screached once - when i forgot to put the shims on >_<
K500's should be quiet as..
So when do you think the GB for the R33 GTSt brake lines will be starting?
Cheers mate!
7/1/08 lines should begin to be shipped out as thats when BrakeWest re-open
Just bend the indicators up a couple of mm. You would be amazed how much pad is still left when it hits the indicators. I bent mine up around 5 times. When I fitted my new pads I pre-bent the indicators up to around 1mm left, so I know when it hit the indicators the pads actually are getting low.
Yeah theres always heaps left. But they already fade like crazy when coming down from high speeds.
Lol i just wait till they snap off...when i hear metal on metal its time to change haha.
    • Not sure if you're being serious? I, and all the car people i know, ALWAYS use a torque wrench for wheel nuts. I assumed any car person, apart from tyre centre monkeys with rattle gun in hand, would do it properly.  Anyway, no further reply from me on this unless legit discussion from OP or his query so, over to you, knock yerself out.
    • I was wondering about this. I'll do some research.
    • Why not? Since mines been built, I've used low boost maybe 5 times.
    • Yeah, so widen your search to any Nissan speedo first, then go wider if needed. I will say though, that there is a better than even chance that what I said first will likely come into play. They quite possibly won't come apart without damage. I tried to disassemble a stepper gauge that I wanted to repair. There was no way that needle was coming off the spindle, and I could not see how the spindle would come out of the mechanism behind. Assembled once, never to be disassembled, was my conclusion. Could be the same on the R34 cluster. Failing that - take the cluster to a workshop that specialises in automotive instrument work. There's usually at least one in every Australian city. They'll either be able to do it for you for small cost, or tell you it can't be done. It might be that "it can't be done" unless you follow some arcane procedure, including trickiness to glue it back together or something, that only experienced techs know.
    • Well, given that I, an engineer, almost never bring out the torque wrench to tighten up chassis bolts, despite fully knowing the theory, and instead rely on feel, which I happen to know is exactly how the majority of mechanics do things, should tell you the level of actual peril that exists from not achieving exactly 88 Nm of torque. How about if I just say then that 88Nm is at the lower end of the correct wheel nut torque range? Everyone knows how to tighten a wheel nut, right? And almost no-one ever brings out the torque wrench for that task
