Would be cheaper and less headaches if you dealt with QFM directly, and got existing backing plates re-bonded with K500 or K750 material. QFM don't make Brembo pads as a standard item, and need to be specifically ordered.
okay thanks mate
  • Replies 433
Posted Images
No there in both in stock.
ok so what am i looking at to get both the braided line and the k750 pads for a r32 gtst? 4 piston front twin piston rear
Hoses = $230 delivered anywhere in Aus.
K750 pads (fronts or rears) = $110 delivered anywhere in Aus
Cheers
Any idea what this would cost for the K750s?
  • 3 months later...
hey mate is this offer still available?
looking for full braided lines for r32gts-t and the KF500 pads if they still around too.
Could you please PM me with details.
Thank you!
Brake West have the measurements for the R34 25GT Sedan if anyone else needs them.
I ended up getting mine custom made direct from brakewest to suit R33 GTSt Brakes.
Great quality lines, good price, good service, very quick!
intrested in Package 1 for R33GTST
1 x Full set of ADR approved braided hoses
1 x K750 Front Pads
1 x K750 Rear Pads
Is the price still $395 Delivered??
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
    • Time: Saturday 18th January - 9am -10:30am Where:  Cafe By Lamanna 10 English St, Essendon Fields VIC 3041  - https://g.co/kgs/mhVKvAB Registration: So we can give the cafe a heads up on rough booking numbers please rsvp below Registration Link: https://forms.gle/wPtfj9Gp8bvCiouo8
    • Welcome Gabriel. At least your car has a glorious RB and not the shitty CA18. As MBS206 mentioned all the good bits can be added later. Two doors or four?
    • And half of them have been converted to turbos.
