  • Replies 433
Posted Images
I have braided lines from this crowd on my GT-T, (also using Motul R600 fluid) excellent product! Improved pedal feel heaps. As for the QFM K500's IMHO they are crap. I had a set of these front & rear in my GT-T, I did 2 club days, one at Baskerville & one at Symmons Plains and they where fried to a crisp & worn out! Only done about 6 to 700 km on them. Will never touch them again. The std Nissan pads are better! Never suffered fade on them but the K500's at the hairpin at Symmons, pedal went hard as a rock & straight off in the sandpit!! Not happy!!
Like I said this is my opinion.
Why on earth would you use a heavy duty street pad on a track??
The K500's are not designed for track, the K750 "Trackday" pads are, hence the name.
The fact you even managed to get 2 trackdays out of a street pad, says alot for the pad.
Thats almost as intelligent as using Safeway engine oil in a V8 supercar and wondering why your engine blew up....
Edited by markk
My mechanic said the only problem with QFM pads is after he fits them they don't see that customer again because the pads last so long lol. When fitting though discs must be machined (or new) or you'll get no where near the pads potential also fitting all 4 at once can give you issues because they take a bit more to bed in completely. They're also supposed to be friendly to the discs which surprised me.
Pretty good so far and the braided lines definately give a much better pedal feel.
Guest
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
