  • Replies 433
Posted Images
i know they make them for s14/s15 but can u get them? same price?
do they make k500 pads for s14/s15 rear?
cheers
I just called BW to ask.
They sure can get them.
Same price.
Interested in package 1...just wondering whether or not the K750's are suitable for a daily, that will see the track occasionally...are they a very noisy/dusty pad?
Currently running Bendix Ultimates on the fronts, no real noise, but extremely dusty, and I have white wheels...:ninja:
Currently running Bendix Ultimates on the fronts, no real noise, but extremely dusty, and I have white wheels...:huh:
The K750's are great from every day driving, as their operating temp is 0 - 750 degrees celcius. I didn't experience any noise when I had them on my car, and I haven't had any complaints from other people.
They are a dusty pad, but not as dusty as the bendix ultimates.
howdy, if group buy is still open I'll take a set of front and rear K750 brake pads, i may even take the whole package inc braided lines, (just waiting to see if a mate is going to give his braided lines up first) but definetly want a set of front and rear K750 brake pads, pm me with the bank details and i will notify you with amount deposited amd what i will actually end up getting, Damo
hey mate im after a set of k750's for an S15 - rear..how long will it take to get them and how can we pay?
cheers
PMs Sent :)
Guest
    • Update 2: Today I'm f**king pissed. Some of you probably saw my thread that I opened shortly after joining this forum, "urgently need expert/experienced opinion", in which I discussed the possibility of a porous RB26 engine block which I also found hard to believe. Currently both turbos are out since the shitty braided line that was installed by whoever fitted the GT28 turbos leaked oil onto the exhaust. Today while working on the cam covers to put new gaskets and half moons in, I cleaned the side of the engine block with brake cleaner. Some time later I saw that it was still glistening with oil or coolant so I dried that off. But it was wet again shortly after. Verdict: I'm royally screwed. What you can see here (hopefully, despite shit resolution), circled in red, is a crack above the turbo oil feed. Extent is a few cm long and basically goes from #3 cylinder wall to #4 cylinder wall. It slowly lets coolant through, even without any pressure behind it. I am absolutely dumbfounded as to how this crack even formed, especially since it isn't along the cylinder as it usually is but rather a horizontal crack. Probably a few cm in length. Not sure on how to deal with this issue right now. Most likely, the only true fix is a new engine block, and even a relatively well done temporary fix requires at least a full engine teardown. Neither of those really fit my timetable right now, the car has been in my buddy's garage long enough as it is. I'm open to suggestions, but I'll be looking into ordering a new 05U block soon so I have one ready for the coming year, or whenever the current block inevitably fails fully. (Most likely once the crack reaches one of the frost plugs) I think it'd be a waste of money and time to rebuild the engine with this block. Oh and I found a rust hole on the side pocket of the trunk, which someone covered up with sealant goop, a piece of number plate and bodywork filler. Fun times. So far for every issue we fix we just find a new one that is arguably worse.
    • I have not found this no. I put one back on a couple days ago with no drama. I agree they are tight, but no need to remove anything.
    • That is gates blue racing belt
    • Anyone found gates blue racing to be extremely tight/ almost impossible to install without moving the exhaust gear
    • Hello am apex am new here and also thanks for helping registering the forum
