  • Replies 433
Posted Images
besides brake dust, why would you choose the k500's over the k750's?
If you're not doing track, then you wouldn't need K750's. The way I see it, you get a better pad for only $35 more.
what lines would i order for a R32GTR with R33 brembos all round? cant imagine it being at all different to normal lines...
Yeah just the standard 32 gtr lines will fit.
Thats the same setup i have on my car
so by better pad, you mean the k750 over the k500??
i do have a track day coming up on march 14th, but realistically i would be doing maybe 2-3 track days a year. Would this warrant though going up to the K750's??
I assuming there is also a trade off in 'rotor wear' from the k500's to the k750's?
Yes by better pad I mean the K750's over the K500's.
If you're doing track days, then I would strongly recommend the K750's. The K500's aren't designed for track.
Yes, there is a trade off in rotor wear from the K500's to the K750's, however I think its negligable.
You'll probably find your brake fluid will boil well before the pads reach their max temp. If you're going track, get some Lucas brake fluid.
Cheers
hi i just need pads..will the k500s fit the stock setup? and is it good just for street driving? noise wise compared to the stock one? thanks
I'm assuming by stock setup you mean for a 33 gtst?
Yes, K500's are ideal for street driving. They produce no extra noise.
Cheers
Guest
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
